BX1800 Won't Start
   / BX1800 Won't Start #1
tbr701
Zanesville, Ohio
Kubota BX1800
Yesterday I power washed my tractor. Today I hooked up the front end loader and had used the tractor for about 30 min. I had to get off the tractor to hand load the front end loader with some items and turned the tractor off. Got back on the the tractor would not start. The battery would click but engine would not turn offer. I make sure the tractor was in neutral and the PTO lever was not engaged. When it would not start I pulled the battery to make sure it was charged and cleaned the terminals. Reinstalled the battery and still would not start. I am now assuming that one of the safety switches on either the gear lever or the PTO lever might have gone bad. Is there was way to check or bypass these switches to know if they are bad and or which switch is bad. I did not know if I disconnected them would by be the same thing as bypassing them or by disconnecting them that it would be unable to start the tractor. Any help would be appreciated.
Disregard my earlier post. Let the tractor sit for awhile and went out and it started. Not sure what the issue was.
   / BX1800 Won't Start #3
Good to hear. I haven't had any issues with my 1860 but I'm always curious to see what issues others are having so I"m as informed as I can be should something go wrong. If your issue happens again, it may be temperature related.
   / BX1800 Won't Start #4
I would bet that some water from the power washing trickled into a circuit or switch somewhere and caused a temporary short. It evaporated and the circuit was reestablished. Glad it worked out.
   / BX1800 Won't Start #5
Mine did the same thing - wouldn't start, tried again later, would start - until one day it wouldn't start at all. That time it was the PTO switch. The PTO was disengaged but apparently the lever just wasn't depressing the switch enough. I'd even tried moving the lever back and forth to be sure it was off.
Just before giving up, I held the switch down with my finger and started it up. After that, it's been fine. I haven't adjusted anything, it just works now.
Guess what I'm saying is, don't discount that PTO switch. It's fickle.
   / BX1800 Won't Start #6
The dash switches are notorious for not being waterproof on the BX1800/BX2200, so I wouldn't be surprised if there are other places that water can get into to cause mischef. I haven't had that problem after washing, but my lights do go crazy if I leave the tractor out in the rain!
I do agree with the pto switch being sensitive. I have gotten into the habbit of pulling the pto lever when I start.
   / BX1800 Won't Start #7
I've also been bit by the pto switch on my bx1850.
   / BX1800 Won't Start #8
I had a starting issue about a year ago, went through all the troubleshooting mentioned in the post only to find out I had a bad battery cable. Just something for everyone to keep in mind. I've got a early BX1800, just a couple of months into production, when I went to delaer for a replacement cable, he mentioned that he has seen problems with battery cables on the early BX's he sold.
   / BX1800 Won't Start #9
My BX1800 was 100% submerged when Katrina hit and destroyed our home. The tractor was only 2 yrs old 100 hrs. No insurance on the tractor. It sat for 4 days flooded out. Fortunately it was only under water for about 1 hr then the water subsided. I was desperate to get the tractor running due to having to clean the downed trees preventing us from getting into our home. I drained all the fuel, oil and hoped the transmission was tight sealed. The engine did not freeze up and I used a bar to turn it slowly by hand until it would make a 360. Gauges were definitely not water proof as being under water all had water. The intake manifold was full of water and I used a wet vac to pull the water out. NO attempt was made to spin it over until the engine turned over with no binding. Unfortunately due to location there was no dealership within 100 miles for me to get parts and the tractor HAD to run. I put 3 gals of diesel and tried to crank. The starter would not turn. The hammer wrench was gently applied and the starter engaged and began to spin the engine. I did the unthinkable. after it was spinning over but not starting I poured directly into open intake about 1 table spoon of diesel. (OK not a good thing for rods and heads but remember this was a desperate time).
Finally the engine fired and ran. IT ran about 2 minutes then began to blow white smoke and died. Thought I blew the head gasket. I pulled the filters and had nothing to replace them so I went direct by pass with copper tube. All the filters were out, fuel and air. (yes I did fill with new engine oil)
I had forgot about the fuel recycle to the tank. When I drained the tank there was still water in the return line. Another 2 hrs went by and I had it flushed and running. Then it began to miss. Now I am thinking trash in a injector. Remember I have no parts supply and we had national guard curfew.
Finally the engine hit on all cylinders and ran well. It was 2 weeks before I could get filters. I was forced to run the tractor about 25 hrs with no filters. Later after the the home was rebuilt I pulled the 4wd, hydrostatic transmission for fluid change. Then I pulled the starter to disassemble and clean. You really dont' want to know what was in it. So you folks are right .. It isn't water proof and water will prevent it from starting. Hopefully you NEVER have to work on the items I had. My F150 truck was next to the tractor and it was also flooded to the top of the air cleaner. I was able to salvage it also as It had no flood coverage on either.
After 5 years and another 125 hrs the tractor still is running all origional parts exclusive of ps hoses and a loader hose. I wish you guys the best. This is my first time on this site and if I can be of any help I will be glad to do so.
Dont' know how long the tractor will last but my guess is due to the TLC it got after being fully submerged it will out last me.
vettdvr way down south.:)
   / BX1800 Won't Start #10
Glad to have you on the forums. Nice to see the BX made it through the storm. I'm sure you were glad to have it when you really needed it most! I know how it is... I'm just inside the Louisiana border in Texas where Rita and Ike made direct hits. I'm up above I-10 a bit so fortunately I didn't have any flooding... but those 130+ mph winds during Rita weren't too nice either!
Toro Z Master Mower (A50324)
Toro Z Master...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
UNUSED JCT QUICK ATTACH BACKHOE DIGGING ARM (A51244)
UNUSED JCT QUICK...
(4) Stand Alone Texas Panels (A50515)
(4) Stand Alone...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
