bx1800 light problems
   / bx1800 light problems #1
ncviauk
Eden
BX 18--
I just change out my battery and fuses but my headlights and turn signals are not working. I have power to my fuse block and the switches are connected but still no lights they were working.
   / bx1800 light problems #2
I dont think its your battery nor fuses. I think its the switch.
Is there a power regulator I can't find the wiring diagrams
   / bx1800 light problems #4
before you get too involved - you need to know that its a common issue for that round light switch to have water in it preventing it from working right and can rust. Just make it easy on yourself and replace that switch in the dash.
So replace all four switches
I Checked the switches still no luck.
   / bx1800 light problems #7
Have you checked continuity through the switches? These switches are problematic. I own a BX23 and have had multiple issues with the switches. Three times in nearly 500 hours, I have had to take the switches apart and clean out the water and corrosion.
I have taken the switchs apart and found the same problems. I just purchase 2 new switchs and cleaned the third.
   / bx1800 light problems #9
I have the your tractor's brother, the BX2200. I have just a little south of you in G'boro. Glad you got it all sorted on the lighting.
Just north of greensboro here
2013 ISUZU NPR STAKE BODY TRUCK (A51219)
2013 ISUZU NPR...
IH 470 Disk (A50515)
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
2016 Nissan Sentra Sedan (A50324)
2016 Nissan Sentra...
1261 (A50490)
1261 (A50490)
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
