BX1500 Transmission filter
   / BX1500 Transmission filter #1
KEVIN7
Southwestern PA
I pulled a dumb one last night rushing to do the 50 hr tranny fluid and filter change last night on my BX1500. In haste, I took off the bottom bolt near the filter that looks like a plug. Of course, along with it came down the washer, spring and a small silver ball bearing. I put the ball bearing back in first, then the spring, washer and bolt. Before I use the tractor again I want to make sure I put it back in the correct order(spring and ball). Anyone have any reassurance or comments out there. I would appreciate it.
Sleepy KJ in SW PA
   / BX1500 Transmission filter #2
I think you have it right. Look at the attachment. I am guessing you are talking about items 100, 110, 120, and 130.
Hope this helps.
Davel
   / BX1500 Transmission filter #3
Trying again.
DaveL
   / BX1500 Transmission filter #4
Here is a link that should take you to the parts list for the 2200. I am not sure but if you substitute 1800 for 2200 you might get the manual you need. This link was supplied by tractorsmart and is really great at looking up how things go together. The torque values for assembly are probably covered in the shop manual.
best of luck
http://www.tractorsmart.com/Books/BX2200.htm
Thanks Dave and Sandy. I called the dealer shop and they looked up the drawing and it said spring first, then ball, seat and bolt so I reversed the spring and ball last night. The hydraulics worked both ways so hopefully it was no big deal. Seems like a pressure check valve type of thing. You can see the spring when you take the tranny fluid filter off.
   / BX1500 Transmission filter #6
You had it right the first time as you can see from the exploded parts diagram. The spring holds the check ball against the oil by-pass passage seat. This is to allow oil flow past the filter if it becomes plugged.
   / BX1500 Transmission filter #7
Sandyc,
Thanks for the link. Already downloaded in their own folder, soon to be on cd. A great resource.
DaveL
Thanks guys! I'll switch back to the way I had it tonight.
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2014 Ford Fusion SE Sedan (A50324)
2014 Ford Fusion...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
John Deere 1770 Conservation 16 Row Planter (A50774)
John Deere 1770...
Club Car Electric Utility Cart (A51694)
Club Car Electric...
2016 Kubota SSV75 Skidloader (RIDE AND DRIVE) (A50774)
2016 Kubota SSV75...
