DaveInColorado
I now have 136 hours on this beast and do every bit of maintenance per the schedule with Kubota filters and synthetic Rotella T for engine oil. My boys put more hours on it than I do mowing lawns so this problem could have existed for a week or two prior to me noticing it (though I did ask and they said they didn't notice - duh). When I'm using it, it is usually the FEL, tiller, or box blade and consequently I'm rarely above 1/2 throttle. Tonight I had to drive it about a mile so I put my ear protection on (with radio) and put the pedal to the metal and let her rip up the road at 8 mph. I'm not positive when it happened or if I just didn't notice it at first, but before I reached the destination I started to notice it "missing", then noticed it was smoking just a bit; too much fuel smoke, not burning-oil-engine-on-fire overheated smoke. I had to mow a steep ditch for about an hour at 2/3 throttle, then headed back home at 1/2 throttle. It runs like normal at 1/2 throttle. Arriving home, I removed the air filter to take a look. It was brand new 36 hours ago. I did the Kubota recommendation (I don't like it) and used a little air to blow it out from the inside. Reinstallation didn't change a thing. I guess the next thing I'll do is replace the fuel filter which isn't due until 500 hours. We've had some rain recently and quite a lot of below freezing nights and warm 70 degree days. I guess I could have water in the fuel filter from the temperature cycling. That would not bother me if that is all that I need to change. I've gone through at least 15 gallons of diesel in the last month or two.
Any hints on what might have happened and how to fix it? I checked the Operator's Manual - nothing of any assistance. The water temperature was a little below normal and the water level is fine. I check the oil every week or so and the last time I checked it was still where I left it 36 hours ago - top mark. I didn't hear any weird internal engine noises. Like I said - it feels like a clogged air filter on a gasoline engine but I really don't think that is it. We have grass everywhere we mow and the dust is minimal. However, and a big however, I do have to replace the air filter every 25 hours on little MTD lawn tractor because it clogs up and starts running rich and diluting the oil with gasoline. Cleaning the air filter lets it run another 15 minutes - no more, so I have to replace it. Maybe that indicates that it is dustier here than I estimated.
My son will be using it today to mow a 2 acre field and 1/2 acre lawn. I told him to keep it under 2/3 throttle where it doesn't smoke and still runs good and to bring it back home if things take a turn for the worse.
Just to make things more complicated and screw up your analysis, after putting the air cleaner back on it was running very slow and very strange. A throttle adjustment didn't have any effect so I grabbed the throttle cable to see if it was broken and all of a sudden it started idling normally as soon as I touched it and the throttle worked again. ???? /forums/images/graemlins/confused.gif I'll give the throttle connection a good lookover tomorrow when it is light.
