BX1500 - lesson learned
   / BX1500 - lesson learned #1
DaveInColorado
Fort Collins, CO
Kubota BX1500
I really hate putting the MMM deck back on, which lead to this problem. I tilled a 1500 sf section of lawn to about 6" deep last Saturday in preparation for running a landscape rack, removing rocks, smoothing out, and adding compost so I could seed it this coming Saturday. I neglected to pay attention to the weather forecast! We've had lots and lots of rain over the past two days turning my lawn into a huge, deep, and sticky mud pit. I've been using both the FEL and rear tiller, plus the MMM is still on the tractor (we usually mow something almost everday). The tractor is heavy!!! So - there's an old garage door on the basement at the back of house that is crooked and the task of fixing it hasn't made it to the A list yet. Wife finds two mice in the kitchen, attributes the mice problem to the cocked door, so I need to get it shut. The easist way is to just lean the FEL on it, right? There's mud down there, and lots of it! I startup the BX1500, put in 4WD, and plow on through, having lots and lots of trouble almost getting stuck. Finally figured out the problem. The deep, chewed up mud was hanging me up on the mower deck! I did finally get the job done but it wasn't pretty. I'll never get the BX1500 out of there if the sun doesn't come out and dry things up.
This is Colorado, dang it. It isn't supposed to rain this much.
   / BX1500 - lesson learned #2
I feel your pain. The rain in WNY is way over the norm. Like you I need to plant grass seed in the yard but it's too wet. I have not even bothered yet to mount my MMM on the BX2230 because of this. I have an old Craftsman to manage the yard until it dries up. At this rate it'll be next year. /forums/images/graemlins/frown.gif
   / BX1500 - lesson learned #3
So...
Which lesson did you learn?
To pay more attention to the weather forecasts...or...
To learn to love removing and installing the MMM?
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif
   / BX1500 - lesson learned #4
I don't understand the problem with installing/removing the MMM. It's very simple, takes me about 3-4 minutes to put it on and like 2 minutes to take it off.
   / BX1500 - lesson learned #5
I forgot to add that something that makes the mower installation MUCH easier is to lift the front wheels off the ground a little, either with the loader (which I don't have) or by driving the front wheels up on something about four inches or so high (old fence post pieces, which I do have... /forums/images/graemlins/frown.gif )
Even on gravel...it makes all the difference and it is not a big deal at all... /forums/images/graemlins/smile.gif
   / BX1500 - lesson learned #6
</font><font color="blueclass=small">( I don't understand the problem with installing/removing the MMM. It's very simple, takes me about 3-4 minutes to put it on and like 2 minutes to take it off. )</font>
Same here. And I don't have any special techniques, nor do I raise the machine's front wheels. All I do to install the deck is raise the lift links, turn the height knob to "0", roll the mower under the deck, lower & connect the lift links, install & connect the front links, connect the drive shaft, raise the deck, change the gauge wheels around, set height knob to desired cutting height, and VIOLA. Done. Granted the 60" deck weighs a bit more than my 54", but you don't really have to manually lift the deck to do this (unless you forget a step, as I sometimes do).
Why are so many people having trouble with this? Or is it just a vocal minority?
   / BX1500 - lesson learned #7
When I first got my BX23, I had trouble putting the mower on and off, but now that I know the tricks, it's easy.
   / BX1500 - lesson learned #8
I don't even rotate the wheels. I can slide it with no problem on my concrete gargae floor with the wheels in their normal position. Although rotating the wheels would make it much easier fro those who are unable to move heavier objects.
   / BX1500 - lesson learned #9
Henro,
Great Idea!! I have a problem climbing under my bx2230 to attach the drive shaft to the pto. Not much room and I'm not even that large /forums/images/graemlins/shocked.gif Next time I will use the FEL and lift up the tractor a little. That would make a big difference. /forums/images/graemlins/grin.gif
   / BX1500 - lesson learned #10
I agree with not having to turn the wheels on the deck. My 60" just slides great on the concrete. Took me 4 minutes to install the MMM today. (It was a Test)
KUHN SR110 GII LOT NUMBER 39 (A53084)
KUHN SR110 GII LOT...
2007 FREIGHTLINER BUSINESS CLASS M2 T/A DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2020 JOHN DEERE 331G SKID STEER (A51246)
2020 JOHN DEERE...
JOHN DEERE FC20M LOT NUMBER 55 (A53084)
JOHN DEERE FC20M...
378492 (A51572)
378492 (A51572)
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
