BX1500 Deck leveling
   / BX1500 Deck leveling #1
KEVIN7
Southwestern PA
I finally removed the FEL and mounted the 54" deck on my BX1500 last night. It was not a perfectly level spot and I was wondering how much affect that would have on the deck being level. All went well but when I pulled it into the garage I noticed there was about a 2" difference between the height of the right side vs the left. It's over a year old and I have had the deck off before but before I start adjusting the linkage, I wondered if anyone had any suggestions. I do plan to lower it in the garage tonight and reconnect everything but if that doesn't work should adjusting the lift arms take care of it. Any thoughts or precautions??
   / BX1500 Deck leveling #2
If you are off by 2" I would guess one pin is not seated properly. The manual details the adjusment procedure but if it was right in the past it may just be a mounting issue.
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A52748)
2020 Massey...
2012 FORD F-650 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2012 FORD F-650...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2025 JBX 4000lb 48in Forks Skid Steer Attachment (A50322)
2025 JBX 4000lb...
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
1000 Gallon Fuel Tank (A50121)
1000 Gallon Fuel...
