Ballast BX Wheel Ballast
   / BX Wheel Ballast #1
botalvr
I would like to ballast my wheels on my BX2200, does anyone know the best stuff to use? I have heard that windshield washer fluid works, but what is the downfall to using that stuff? And how in the heck do you get it in there?
Thanks!
   / BX Wheel Ballast
Thanks for the link, I was searching for wheel ballast and not tire loading.
So, at the risk of turning this into a hot debate, I have one more question.
If I want my BX to be less likely to tip when mowing, ballast or wheel weights will help, right?
I am gravity challenged... /forums/images/graemlins/confused.gif
   / BX Wheel Ballast #5
Either one will cure your problem. The wheel weights can be taken off easier should you not need them all the time on the tractor.
   / BX Wheel Ballast
</font><font color="blue" class="small">( case wheel weights are under $100 for the pair. )</font>
Thanks! And I bet they won't rust my rims either!
   / BX Wheel Ballast #7
i like the idea of the wheel weights, can be removed so the weight is not always with u.
   / BX Wheel Ballast #8
Do you want Ballast for the FEL? The tire weight might help some, but I highly recommend using a 3pt attachment. Whether it's a design you create, or a implement you'll be happier and feel safer.
Also, I prefer wheel weights over the liquid filled tires. But I'd say it's 6 of one, half dozen of the other.
Kohler 30 Generator (LOCAL TOWNSHIP) (A50774)
Kohler 30...
2012 Chevrolet Captiva Sport SUV (A50324)
2012 Chevrolet...
(4) Radial ST 225/75 R15 Tires (A50121)
(4) Radial ST...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A52748)
2015 Ottawa Yard...
KJ Portable Bathroom w/Sink & Shower (A50121)
KJ Portable...
2013 Dodge Journey SXT SUV (A50324)
2013 Dodge Journey...
