BX Water Pump
/ BX Water Pump #1
BlackforestBill
Bronze Member
El Paso County Colorado
Kubota BX2200
Well it happened again. Last year I managed to over heat my 2000 BX2200 while mowing. Hadn't done a good job of clean the radiator fins. Over heat it a couple of times and you fry the water pump. At least that's what I was thinking at the time. Ordered new water pump. Turns out there are two different ones for the 2000 model year. Depends on when in the year your BX was made. One has smaller blades (that one fits mine). First one delivered was the wrong one, of course. Second one fit nicely. That was last August.
Moved a lot of snow over the winter. Put over 40 hours on the little beast with bucket and back blade. Now it's summer and I've been mowing again. 54" MMM, clean the radiator after every use. High RPMs for 3 hours or more to get the whole property done. Let it warm up before starting the task but just shut her down when done.
On my fifth time mowing I note the temps come up a bit higher and I have a small puddle under the engine in the garage the next day. Yep, water out of the weep hole on the water pump, again.
So what did I do wrong this time? I was careful to keep the fins clear. I watched the temp gauge. I'm using air to clean the debris off the MMM deck, the engine and the radiator. I'm blowing from the engine side. Coolant was a 50/50 mix. Oil is Kubota 10W30 (dino). It's just under 300 hours total use.
At $154 a pop this is starting to get expensive. At least I can do the R&R myself. Any ideas on how to prevent this in the future?
/ BX Water Pump #2
Let me get this right...you replaced the first water pump that wasn't leaking, and now the you replaced it with is?
/ BX Water Pump
I replaced the first one because it was leaking through the weep hole. Second one is now doing the same.
Impellers are metal but they aren't the problem. On automobile water pumps in general there's a ceramic or similar substance seal. When it goes bad water pours out the weep hole. Not sure what material Kubota uses. Usually goes bad due to high heat. Usually wont pour out the water when hot (expands and makes a decent seal), but as it cools down, and you're no longer around the tractor, it opens up and you get Niagara Falls.
/ BX Water Pump #5
Is the fan off balance? If anything coming off of that shaft is I could see that causing early failure. I had a similar problem with my truck that caused me to replace 2 pumps in a 6 month period.
Otherwise I'm guessing a problem with the design of the pump....heat alone shouldn't kill the pump.
/ BX Water Pump
Hmmm, good question. I'll check it when we pull it for the swap. I was thinking too much heat shouldn't cause early failure and was wondering what might have caused the demise of the second one.
/ BX Water Pump
638 said:
Belt too tight???
ron
Good idea. It is pretty tight. I'll check the deflection before we tear it down and I'll make sure to set it to the setting in the owner's manual (I think I saw it in there).
-Edit- I just checked the deflection. Manual says between 1/4 & 3/8". It's in that range.
/ BX Water Pump #9
Let us know what you find, I'd be curious to know, something has to be killing the pumps off that early.
/ BX Water Pump #10
I just went out and checked mine (BX23) and I'd say I have about 1/2 or so deflection and that almost feels too tight.
Overheating may have eat up the seal in your original waterpump but that 2nd one should have lasted a whole lot longer than it did. I've only got 260 hrs without any problems w/the cooling system but this is not enough time to tell if something isn't engineered right but I'd guess that 2nd pump was defective or the belt was too tight and that it is not an engineering problem.
I've not heard of many waterpumps needing changed on BX's here on tbn so I wouldn't think that they all have short lifespans.
I've never had to adj my belt and I may even loosen it abit when I do the 300 hr. I just know from having to wrench auto's that an overly tight fan belt will eat up waterpumps and alternator bearings, btdt....
Good luck
/ BX Water Pump
I was reading something interesting in the owners manual. It says if you over heat the engine to not shut it off. You're to "stop in a safe place and keep the engine idling unloaded." "Don't stop the engine suddenly, but stop it after about 5 minutes of unloaded idling."
That's on page 51 in the Checking Radiator Hose and Clamp section.
That may have been a contributing factor on the first one. I did over heat the engine a couple of times and immediately shut it down. That was before I figured out how to really clean the radiator (thanks TBN!!). But I don't remember over heating it since replacing the water pump.
I'm thinking next oil change will be to synthetics, I'll add something to the cooling system to help lower temps and if it still runs hot (it always has) I may add an electric fan.
/ BX Water Pump #12
i dont know the rpm's for that tractor but lets say its 3500, try running at 2800. it may still have enough power to do everything you need. mine is supposed to run at 2100 rpm, i never need any more than 1800 rpm for shredding and run at 1200rpm for post hole digging. this may cure your heat problem.
/ BX Water Pump
I thought about that. There's a couple of issues with the idea. First is I live at 7660 feet above sea level. At this altitude my 23 HP is closer to 19. That's why I went with the 54" deck instead of the 60". Also, lower RPMs bog the engine down whenever I hit a high patch of weeds and at the lower speed I don't get near as clean a cut.
I may have to sharpen the blades and mow more often to make it work. But it sure would beat the over heating problem. I'll have to give it a try once I get it back running.
/ BX Water Pump
It's looking more and more like a defective pump. I ordered the replacement today. The part number has changed due to a change in suppliers. Now I wonder why they'd do that? I know, it could be a cheaper supplier, the other company may have gone a different direction, etc, etc. Lots of reasons companies change part suppliers. But one of them is because the previous supplier's products had a high incident of failures.
Here's hoping that the new one lasts a good long time.
On another note, I've decided to replace the fan belt while I have it apart. It was only $12 for the replacement. The old one looks pretty good, but there are a few small nicks in it. Any thing special I need to be aware of when making the change?
/ BX Water Pump #16
i got my 70 year old father in law a 16 hp diesel yanmar with a 4 foot shredder, we use it at 2000 rpm's, when it starts to bog down we just give it a little foot throttle and its fine, i mow small trees with this thing, 3 inch diameter trunks like its nothing, and big patches of sunflowers just as big. its not hydrostat but if it was i would use hand throttle when i hit the big stuff, ill bet your tractor can handle it at a lower rpm.
/ BX Water Pump #17
I have had the same problem.
My water pump has gone out for a 2nd time. The first time the engine was overheated after mowing extremely long grass.
It was replaced in Sept. 06.
It just went out again. I pulled several loads of firewood in a utility cart on a cool day, and the engine was nowhere near overheating.
Doesn't seem like a water pump should go out that frequently.
Not looking forward to replacing it again as it's difficult gettng that fan out.
2025 MMS MS36CJ (A60463)
2025 MMS MS36CJ...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
JOHN DEERE 850K WT CRAWLER DOZER (A62129)
JOHN DEERE 850K WT...
2024 Deere 335P (A60462)
2024 Deere 335P...
Iranch IRGC40 (A60463)
2025 AGT Industrial MX-MRW14 (A60463)
2025 AGT...
