BX vs ZD for mowing
   / BX vs ZD for mowing #1
TMGT
Elite Member
Stafford, VA
B2620
I'm thinking about selling my ZD331 and buying a BX2680 with loader (used).
I know the BX cut speed and cut quality won't be as good, but I like the idea of having a machine I can use year round and for other task.
The only experience I have on a BX mowing has been with a BX1500 a few times and a BX 1870 with a 54in deck that I bought to flip last year.
Both seemed to do a good job, but it was late in the season for the 1870 and I didn't really get to try it out in the thicker grass.
My current Zd331 has a 72in deck, a hard shell collector, and a mulch kit that I put in for most of the mowing season. I would miss the hard shell collector, but I'm sure I can adapt something to it in the future.
Does anyone have back to back experience with the larger ZD mowers compared to a BX?
The propert is a put 2.5acres of mowing, mostly tall fescue, thick in some areas. I just don't have as much area to mow as I use to so the larger deck is not as necessary.
Just trying to see if I'll be annoyed by the BX as a mower.
   / BX vs ZD for mowing #2
I have a NH 25S (25 HP) tractor with a mid-mount 60" mower deck and a Kubota ZD1211 60" ZTR. I use the 25S to mow about an acre of rougher areas and the ZTR for my finished yard of about 2 acres. The ZD1211 will mow twice as fast as the 25S but I feel like I am beating me and it up in the rougher areas. The cut on the 25S is acceptable on the finished yard.
I call the 25S my powered wheelbarrow. It is very handy for doing dirt work around the buildings and other small tasks. I just put 3 yards of mulch in the flowerbeds in very short time. I got 6 yards in my dump trailer and dumped it on the driveway, then scooped it up with the 25S. The 2 landscape guys that were raking it out said it cut the time in half from them using a shovel and wheelbarrow to move it.
   / BX vs ZD for mowing #3
I bought my BX 2680 for the sole purpose of mowing. I have places that a zero turn just won't go. I even had the remote driving mode installed at the dealership. LOL
Thanks, I know it'll be slower then the Zd, mainly wondering how the BX cut quality will compare. I have a larger L3240 for heavier tractor work.
While I like the z it's a one trick machine, it would also be nice to have a smaller machine to get into places the L doesn't fit.
   / BX vs ZD for mowing #5
Years ago I tried mowing with a mid mount on my then owned BX it was ok but not great as it is less nimble than a zero turn, slower and the blade tip speed is slower . Plus if I left the front loader on getting into tight places was harder. For the last 20 years I have mowed with a ZD currently a ZD 1211 26 hp diesel with a 60” deck great mower and my BX stays configured as a tractor without the reduced ground clearance of the mid mower. My normal mowing is just over one acre But I have mowed our community grass runway 2100x 200 in less than a hour with the ZD that said theBX as a tractor and the ZD as a mower each does its job better than the other
   / BX vs ZD for mowing #6
I,ve owned a BX2350, BX2360 and now own a BX2370. I get tons of compliments all summer long on how great our lawn looks. As long as you are not in the most beautiful looking lawn contest all summer, go ahead and get it, it will do the job just fine. I also have the front bucket, snowblower, weight box and rear scraper blade for it, it is a great all around machine for our 2 acre property.
   / BX vs ZD for mowing #7
I don’t think the cut quality will be much different, but you’ll leave more tire tracks with the narrower cut swath of the BX.
Have you thought of keeping the ZD and just ordering your BX without a mid mount deck? That would alleviate some of the cost and leave you with a tractor thats more capable driving on bad/muddy ground conditions.
I don't need a bx, it would be more of a replacment for the zd since it has more uses. I would be buying used and selling my zd331, zd21 and probably my Wheel Horse 520h.
I don't care about ground clearance as this would be a secondary machine to my larger L so the mower deck would stay on all mowing season.
I don't mow for other people anymore, so speed isn't as important, the ZD is kind of overkill now.
This whole thought process started after I bought a BX1870 to flip and used it to mow a small field I usually rough cut a few times a year.
It did much better then I expected and was kind of nice to have a second loader/3pt for when the grapple and backhoe are on the L
I've mowed this property with a Wheel Horse 520h with a 60in deck, and Z's with 60 and 72.
Time isn't as big of an issue now that it's mine and not a customers where time meant money.
With the ssqa I can at least pull the bucket off to mow, although the swift-tach loaders seem to come on and off pretty quick if needed.
I didn't get a chance to try out the 1870 on my main yard when I had it, but it's cut quality did impress me when I mowed my rough range area, although that is a mix of grasses including bermuda.
2025 Safety Basket Forklift Attachment (A46683)
2025 Safety Basket...
2008 Ford F-250 4x4 Super Duty Crew Cab Pickup Truck (A46684)
2008 Ford F-250...
Galvanized Pipe (A49251)
Galvanized Pipe...
2011 Jaguar XF Sedan (A46684)
2011 Jaguar XF...
2015 INTERNATIONAL 4300 26 FT NON CDL BOX TRUCK (A45679)
2015 INTERNATIONAL...
2023 Ford Explorer AWD SUV (A48082)
2023 Ford Explorer...
