Tires BX Turning right problems
   / BX Turning right problems #1
BXman98
St. Albans VT
Kubota BX2370
I have a bit of a low tire tire pressure in the front right tire of my BX and if I have a bucket full of dirt and if I am running at about 2300-2500 RPM's, turning left is fine but when I go to turn right it is very tough to do that. I am thinking that it is because of the low tire pressure but i'm not quite sure. I hope that it's just the tire pressure because we just got the FEL like two weeks ago and we can't afford anything to go wrong with the tractor now. It's only got about 165 hours on it as well.
   / BX Turning right problems #2
That sure sounds like the issue. I would fill both front tires to the same pressure and also make sure you have some sort of weight on the 3pt hitch for ballast.
I will try that and I did have a 250 lb rear blade on the back when I was doing that.
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
71056 (A49346)
71056 (A49346)
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A52577)
2012 INTERNATIONAL...
24in Tractor Backhoe Bucket BT4555 (A52128)
24in Tractor...
2019 JOHN DEERE 331G SKID STEER (A51242)
2019 JOHN DEERE...
Flat Deck Trailer (A50322)
Flat Deck Trailer...
