BX Transmission Strainer Bolt Size
   / BX Transmission Strainer Bolt Size #1
Will_C
Veteran Member
Upstate N.Y.
Kubota L3560, Toro 52" and 60" ZTRs, Kubota RTV 900
It seems hard to believe, but it almost time to do the 600 hour service on my tractor. I was wondering if anyone knows the bolt head size for the hydraulic fluid strainer that is located on the left side of the tractor? I used an adjustable wrench for the 50 and 300 hour services, but I want to buy the right sized wrench for this time. Thanks,
Will
Gosh, 50 views and no answer? The TBN brain trust must be on vacation /forums/images/graemlins/grin.gif
Will
   / BX Transmission Strainer Bolt Size #3
I had to use a cresent wrench when I changed the oil on my BX1800 to.I did not have any metric sizes that big.I guess I will have to measure it and get me one.You will probably find out what size it is before I get this done. /forums/images/graemlins/grin.gif
   / BX Transmission Strainer Bolt Size #4
I will take a guess as I just went out to see what wrenches I had to try and tell you. My 1" wrench is too small, my 1 1/16" is too big. My 27mm seems a little to loose as well.
So my guess is it is 26mm which of course I do not have. Of course that figures as I am ready to do my 50hr service, so I guess I will also be using a cresent wrench or going out and purchasing a set with a 26mm.
I also checked the manual quick and didn't see anything to tell the size but didn't go into detail as I just ran home quickly for lunch and have to get back to the office.
Good luck,
Randy, Thanks alot. I will try my wrenches the same as you did (I have some new tools that I have not used /forums/images/graemlins/blush.gif.) If I don't have a 26mm, it will be off to see if Sears has any loose stock. I really want to use the proper wrench, as the bolt was very difficult to remove at 300 hours.
Will
   / BX Transmission Strainer Bolt Size #6
I was able to use the 1-1/16 on mine; worked fine. It was on there real tight; had to use a pipe to break it loose.
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2022 Ford F-750 Super Duty Altec LR756 56ft. Insulated Forestry Chipper Bucket Truck (A49461)
2022 Ford F-750...
2017-2023 Ford 4x4 Super Duty Pickup Bed (A49461)
2017-2023 Ford 4x4...
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
Massey Ferguson 65 Tractor (A50514)
Massey Ferguson 65...
