BX tach needle sticks.
   / BX tach needle sticks. #1
frogpond
Snohomish WA
Kubota BX25D
I have a BX25D with about 650 hrs. When I start it up, the tachometer needle goes way up, as usual, then down to zero, then stays there instead of going up to slightly above idle (where I set the throttle to start). At the same time, the battery light stays on. Both of these persist until I goose the throttle higher, and then the needle comes up and the light goes off.
I have checked under the hood while the needle is zeroed and the light is on, and the fan and alternator are turning. When I check the belt (with engine off, of course), the deflection is normal.
Any theories? No problem running, but I am worried that this might be advance warning of things to come.
   / BX tach needle sticks. #3
Check the tightness and wear on your alternator belt, just in case it might be slipping.
   / BX tach needle sticks. #4
Maybe the tach cable is about to break...just a guess.
Thanks for the suggestions. I'll be able to check on Sunday, and report back...except, how do you check the tach cable?
   / BX tach needle sticks. #6
Does it have a cable? I’ve got a 10 year old BX and the tach is digital. It might not have a cable and be electronic.
   / BX tach needle sticks. #7
Your tach does get the signal from your generator, so missing tach and charge lamp are symptoms of the same problem.
Well, the belt does deflect about 1/2", which is slightly more than spec. To adjust it, you oosen the alternator mounting bolts...but it appears that to get a wrench on the lower one, you have to take off the whole engine shroud. I think I'll wait until it gets worse.
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
Caterpillar 430D 4x4 Extendahoe Backhoe Loader (A51691)
Caterpillar 430D...
KJ 23'x22' Double Garage Metal Shed (A50121)
KJ 23'x22' Double...
John Deere 6215 (A50120)
John Deere 6215...
