BX Rear PTO not working
   / BX Rear PTO not working #1
Anonymous Poster
Epic Contributor
I was using the tiller this past weekend and the rear pto stopped working with the lever in the rear only position. When I moved lever to rear and mid it worked- and I finished my fall "plowing" that way. I wil call Kubota for pick-up and repair. Any ideas on what might be causing this?
Jim V in Wisconsin
BX2200, 73 hours
   / BX Rear PTO not working #3
Was tilling and hit something that popped the shear pin and stopped the PTO from working. It turned out that the spring on the PTO overrun cluch was not strong enough to reset the cluch. The dealer had to half split the tractor (split at the bell housing) and replace the spring - $600.
carl
But why would the rear PTO work when in the middle lever position (Rear and Mid PTO together)?
   / BX Rear PTO not working #5
Sounds to me as if there is a linkage problem. I don't think its a serious clutch problem, as the BX doesn't have a clutch! /w3tcompact/icons/smile.gif I would let the dealer look it over...I'll bet it isn't too tough a problem to fix, especially since it works fine in dual mode.
Keep us posted though, it may help someone else, and besides, we're all curious!
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
378789 (A51572)
378789 (A51572)
2019 D&P WELDING  12FT LUBE TRAILER (A52472)
2019 D&P WELDING...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
