BX Plowing
/ BX Plowing #1
bxsjut
Anyone tried plowing with a BX? I bought a 12" Leinbach and I'm having problems getting things to line up because of the wide tires in the back. I'm only using about 8 inches of the plows 12. Is there a better plow available?
/ BX Plowing #2
The Plow page of the BX Wiki has links to three informative TBN threads on plowing with a BX.
/ BX Plowing #3
I find that a single tooth sub-soiler works best to get the ground prepped. If you put ballast on the plow, and more ballast on the rear of the tractor, it will rip; it will even scratch into true hardpans. From there, you can take further passes with whatever other type plow you desire.
/ BX Plowing
Thanks for the lead to the other discussions. I glanced over them and it looks like just the information I need.
