BX Owners, opinions please.
   / BX Owners, opinions please. #1
Zoomie
Texas
Ford 1700
I looked at the BX2230 tractor today (also looked at the B7510), and it seems so low to the groud, especially at the front axle.
Have any of you, who own the BX series, ever found the slight ground clearance to be a problem?
One other thing: Tires. Anyone have traction concerns with the turf vs bar tires?
I'm not a farmer, and only have about 5.5 acres, which is fairly smooth, to maintain, so I'm thinking the (low slung) BX will suit me fine.
I asked the dealer if he gets many people who've bought the BX, come back wishing they'd bought a B series, he grined and said: "Nope".
He seems to think I'd be happier with the BX, since I'd likely do more mowing than other "chores".
Thanks in advance for your opinions.
   / BX Owners, opinions please. #2
We have uneven terrain and some railroad ties lining the driveway and have yet to have a problem, even once. I have 4 acres, mostly grass, until a recent home addition. The turf tires have suited all chores with the following implements,
Front end loader, Mid-mower, rear brush mover, rototiller, box scaper, rear rake, and posthole digger.
We considered bigger tractors but are extremely happy with the BX2200 as it manuevers around all the trees better.
I can't say enough about our BX2200.
Good luck!
   / BX Owners, opinions please. #3
It sounds like the BX is a great fit for you. The clearance is not an issue as long as you are on level ground, as it seems you are. I put 90% of the hours on mine mowing, and the BX does a great job mowing. I have the turf tires, and simply run chains in the winter and spring for a bit more (probably not needed) traction. The rest of the year, the turfs are gentle on the lawn.
Will
Thanks folks,
No doubt the height of my "little" Ford (I live in farm country where most tractors have cabs and folding implements) is having an influence on my perceptions.
I really liked the size, HST and options offered in the BX series. Unless Massey has something to wow me, that's probably the direction I'll go.
   / BX Owners, opinions please. #5
i've never has a ground clearance issue with either my BX22 or the BX2200 I owned before it. But I don't operate in the woods, either.
As to tires, I ran the turfs on the BX2200 and they worked fine, although the slipped a lot on some FEL work. I switched to the bar-turfs when I bought the BX22 and they are incredible. No marking when mowing and a ton more traction when digging and plowing. I'd recommend the bar-turfs any day for anyone who is not using their BX strictly for mowing.
   / BX Owners, opinions please. #6
Ground clearance hasn't been an issue at all but I never see real rough conditions either.
If you are going to be mowing and using the FEL on grass that you don't want torn up get the turf tires and maybe a set of chains for when the going gets tough.
I have the bar tires and my land is mostly sandy/loamy stuff. the Bar tires are very!!!!!! agressive. I don't mow with mine and I'm being very careful, still I am tearing things up quite a bit. After I finish by big dirt projects. I'm going to have to buy a set of turf tires.
   / BX Owners, opinions please. #7
I think you'd be happy with the BX given that your main task is mowing. If you've got some rough terrain, it might not be a mistake to go larger though. If you do go BX, remember that you can get BOTH the turfs and the ags for only an extra $300. That is mounted on an extra set of wheels and all. This is a nice perk to the BX. Spare wheels are cheap! /forums/images/graemlins/laugh.gif
   / BX Owners, opinions please. #8
I have over 80 hrs on my BX2200 and have used it to mow, move dirt, landscape, plow snow, etc., etc. This is one great machine!! I bought it with turf tires then bought a set of Bar Tires and rims later on to switch over to for snow or when I'm doing serious digging for better traction....not that expensive ...about 300+ bucks. You won't be dissapointed with the BX.
   / BX Owners, opinions please. #9
If mowing will be 80-90% of your work, the BX will be fine. BUT if you plan on doing projects that involve a lot of digging, leveling, and work in the woods, go for the B7510. I have both turf and bar tires. Picked up the bar ties for $275 late winter, will use them next winter for snow. Anything other then mowing will just take a little longer with the BX.
   / BX Owners, opinions please. #10
</font><font color="blue" class="small">( If you are going to be mowing and using the FEL on grass that you don't want torn up get the turf tires and maybe a set of chains for when the going gets tough.
I have the bar tires and my land is mostly sandy/loamy stuff. the Bar tires are very!!!!!! agressive. I don't mow with mine and I'm being very careful, still I am tearing things up quite a bit. )</font>
My experience has been just the opposite with the bar-turfs. Almost no tearing unless I take a tight turn with 4wd engaged. But I'm also carful about how I drive and how fast I'm going when making turns. Even in wet areas, I only get the same "marking" that I got with the turfs on my previous machine. I would not go back to the turfs unless my machine was dedicated to mowing...which it never will be.
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A53473)
FIRESTONE 9.5L-15...
Lockwood 480 Pecan Harvester (A53473)
Lockwood 480 Pecan...
2025 JMR 36in Mini Skid Steer Bucket (A53421)
2025 JMR 36in Mini...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
1993 Ford F-150 Pickup Truck (A52377)
1993 Ford F-150...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
