BX MMM driveshaft
   / BX MMM driveshaft #1
bellweather
Platinum Member
Western MA
Kubota BX22
This is probably no big deal but when I removed the MMM from my BX22 for the first time the U-joint slipped off the drive shaft. I just aligned the splines and slipped it back on. My question is - is this normal? Thanks
   / BX MMM driveshaft #2
I'm not sure I understand what you are explaining. If you mean the driveshaft seperated into two parts, that will happen. Clean, lubricate, and reassemble. I use a bungee cord to keep that from happening when I pull the MMM off.
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A51692)
2015 Freightliner...
Syrup Kettle (A50123)
2018 KENWORTH T800 DAYCAB (A53843)
2018 KENWORTH T800...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
