BX Grease Fittings
   / BX Grease Fittings #1
1funride
The owners manual for the BX does not call out any grease fittings.
I found one on the foot pedal. Are there any more on the tractor?
Seems there should be one on the front axle pivot.
Where can I but a shop manual for this tractor? The owners manual is terrible.
   / BX Grease Fittings #2
The pedal's fitting was added late last year to address a problem, one day the Owner's Manual should catch up to the changes. No other fittings on the unit itself. If you have a belly deck or FEL, they do have their own fittings.
If I remember correctly, a while someone on this board did order the shop manuals from the dealer.
Roy
   / BX Grease Fittings #4
I can't get grease to go into the fitting. I got the paint off the grease fitting and the little ball is free but still can't get grease to go in with a hand type gun. Any ideas?
Glad you brought this up. I had looked for fittings but not seen this one.
thanks,
john
   / BX Grease Fittings #5
You may need a better grease gun, the little ones have a hard time getting grease thru the tight-fitting sleeves on the pedal. It might also help to move the pedal back and forth while putting pressure on with the grease gun (with the tractor OFF of course!). I bought a bigger grease gun and move the pedal...works for me, but it doesn't take much grease to do the job...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2015 Ford Econoline Shuttle Bus (A50323)
2015 Ford...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2002 International 4400 SBA 4x2 Flatbed Truck (A50323)
2002 International...
JMR 68" Root Grapple (A50121)
JMR 68" Root...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A52748)
2019 Tico Yard...
