BX Front Quick Hitch Info B2751 vs B2753
   / BX Front Quick Hitch Info B2751 vs B2753 #1
bp fick
Super Member
Beaver Creek, Northern Michigan
John Deere X390
In a search for a quick hitch assembly, I'm finding these two part numbers. I have a very foggy memory of the BX1500 having the smaller hitch and that it wasn't compatible with the newer, larger BXs.
Does anyone know the differences, if any, between these two quick hitches and their applications to which machines?
The snowblower or front blade is used is ID'd individually, such as BX2763 or BX2763A, etc.
The help and insight is much appreciated.
Well, a fella just called me on the phone and says the B2753 assembly was used with the slightly older B series machines like the B7610 and such. If that info is correct, then that clears that up, I guess.
   / BX Front Quick Hitch Info B2751 vs B2753 #3
Well, on my BX25, the quick hitch subframe is BX2751 and the pto kit which attaches to it is BX2753. The pto kit is not necessary if you only use blades.
Dean
91013 (A48082)
91013 (A48082)
Kubota B7100 Tractor (RUNS) (A50774)
Kubota B7100...
2022 Mack MD Rollback Truck (A50323)
2022 Mack MD...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
2015 Dodge Challenger Coupe (A50324)
2015 Dodge...
2016 Takeuchi TL8 (A47384)
2016 Takeuchi TL8...
