Dean,
I just had the front quick hitch (BX2711) and front blade (TG2754) installed on my
BX1500. I live in New England and we get our fair share of snow and a variety of it too (everything from light and fluffy to deep and heavy). I feel that plowing is much better than using my FEL. The plow set-up is great, except that I am disappointed with the manual angle operation on the TG2754. It requires you to get off your tractor seat, pull a pin, pivot the blade at the desired angle, and replace the pin. I do not like this at all, so I plan to modify the TG2754 by welding a 2"x8" cylinder to operated the angle. I will control the cylinder from my pedestal mounted joystick control vale, which also operates the vertical movement of the quick hitch.
I had called Kubota to question why the hydraulic angle option is not available for the
BX1500 (i.e. why they do not recommend using the BX2763A 60" front blade with the
BX1500). They said I could purchase and install the BX2763A, but that is more of a commercial blade, weighs 250lbs (TG2754 weighs 110lbs), cost about $2000 (TG2754 cost me $350), and they said I could have some performace issues, as the
BX1500 may not have enought power to push a deep heavy snow. They did tell me that they will be offering the TG2754 with the hydraulic angle option next year, but will drive the cost of the plow up around $1000.
I'll post some pics once I finish my modification.
