BX cable cutting tool?
   / BX cable cutting tool? #1
BarryinMN
Platinum Member
Minnesota
JD, Allis-Chalmers, Zetor
Is a hacksaw or Sawzall blade best for this or is there a better less burr creating tool?
   / BX cable cutting tool? #3
I also have bent it until the corrugation snapped apart and used the attached cutters made by Klein
   / BX cable cutting tool? #4
You can get by using a hacksaw if you only have one or two cuts to make. I did not know about the BX cutting tool when I first started using BX and would mess up about every other hacksaw cut. When you discover how good the BX cutter works you will be glad you invested in it and never go back to the hacksaw method.
IMO
Farwell
   / BX cable cutting tool? #5
If you are speaking about a wire rope, I cut many a cable during a year. I have tried every tool that you could think of and a bolt cutter is by far the best. The cable will not ravel and it will be a good clean cut. The first time someone told me to use a bolt cutter for cutting cable I thought that they were crazy. Then I was at a store one day and ask an employee about a cutter. He said to use a bolt cutter. I told him that I didn't think that it would work. He had me go to the spools of cable and try them. I have been cutting cable with that same pair ever since.
   / BX cable cutting tool? #6
AC cable, or trade name "BX" is much different than wire rope. He's talking armored electrical cable here.
   / BX cable cutting tool? #7
Although I have never used one of those BX cutters myself a few of my previous techs did and they swore by them.
   / BX cable cutting tool? #8
I knew that BX didn't make since to me, but I hate working on electrical anything. /forums/images/graemlins/crazy.gif
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
2011 GMC Sierra 4x4 Pickup Truck, VIN # 3GTP2WE36BG213306 (A51572)
2011 GMC Sierra...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A52577)
1993 INTERNATIONAL...
