BX Bagger - Gearbox Service
   / BX Bagger - Gearbox Service #1
r0GuE
Veteran Member
West PA
ex-Bota Owner
Since my local dealer can't sell me AGMA 5EP Amoco Permagear EP220, and since I understand this stuff is generally not sold in consumer packaged quanities, I am wondering what those of you who own BX baggers are using the the gearboxes.
I have heard in a post on the oil forum last summer that: "ISO220EP = AGMA 5EP = SAE90 gearoil API GL5. The GL5 rating is for the extreme pressure additive (EP) in the gear oil. API-GL 5, SAE 90 would work just as good if not better then the original fluid."
If I don't hear any dissent in the next few days, I'll be getting some for use next Saturday. Grass is a growin!
Thanks Guys!
   / BX Bagger - Gearbox Service #3
<snip><<I have heard in a post on the oil forum last summer that: "ISO220EP = AGMA 5EP = SAE90 gearoil API GL5. The GL5 rating is for the extreme pressure additive (EP) in the gear oil. API-GL 5, SAE 90 would work just as good if not better then the original fluid.">>
I used Mobel 1 GL5 last spring when I did mine, but what I drained out looked clean. Didn't have any problems last year. It's a pita to do tho......
Cheers, Richard
   / BX Bagger - Gearbox Service #4
I found Amaco Permagear ep 220 at an oil company in Vancouver, WA. Yes, I had to buy 5 gallons, but it is not the same as gear oil. It is sometimes referred to as liquid grease, because it is so thick and viscous. Really interesting oil. I take a bath in it sometimes. Good for getting rid of skunk smell.
Seriously, there are several equivalent brands, but 90 weight gear oil is not one of them.
Best Regards
John Deere 6110M (A53317)
John Deere 6110M...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
