BX Bagger and Pat's Easy Change Compatibility
   / BX Bagger and Pat's Easy Change Compatibility #1
jhoward000
Alabama
2006 Kubota M7040 Cab, Yamaha Grizzly
BX Bagger and Pat\'s Easy Change Compatibility
I am thinking about purchasing a Kubota Grass Catcher for my BX2200 with 60" MMM. However, after reading all the posts about the grass catcher and looking at the photos, it would seem that my Pat's Easy Change (which I LOVE) would need to be removed before the grass catcher could be properly installed. Otherwise, the mounting points wouldn't align.
Has anyone tried to use the grass-catcher with Pat's Easy Change? Or, has anyone come up with a work-around so that the Easy Change doesn't have to be removed? Removing these each time would be a PAIN.
I guess one approach might be to lengthen the support from the grass catcher that attaches to the top-link bracket on the tractor.
Any info or thoughts would be helpful.
Thanks!
   / BX Bagger and Pat's Easy Change Compatibility #2
Re: BX Bagger and Pat\'s Easy Change Compatibility
Somebody mentioned in one of the threads that it will not work together.
   / BX Bagger and Pat's Easy Change Compatibility #3
That would be me. Here is the thread. Check out the very end. /forums/images/graemlins/frown.gifThread
DRAGON 500 BBL FRAC TANK (A53843)
DRAGON 500 BBL...
2009 DRAGON  130BBL VACUUM TRAILER (A53843)
2009 DRAGON...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
KENWORTH ROLLBACK TOW TRUCK (A52706)
KENWORTH ROLLBACK...
