bx and lp1572
   / bx and lp1572 #1
Anonymous Poster
Epic Contributor
Does anyone know if a 72" landpride back blade(1572) will connect ok on a bx2200 and be able to rotate 180 degreees with out disconnecting from the 3ph? My local dealer has that particular model in stock for $250. Thanks in advance for your responses.
   / bx and lp1572 #2
I have the BX2200 with a RB1560 blade. I looked at the manual and it appears that the RB 1572 uses the same frame. With that said it seems to me that there would be adequate clearance for a full 360 degree spin of the blade. There is more than the additional 6 inches needed (the blade is 12 inches bigger but only 6 inches matter in this case) to clear any obstructions. (Assuming you do not need to offset the blade and it is centered on the frame.)
BTW, wouldn't the dealer let you try it or understand that if you can't rotate it than you would return it, or is the dealer located very far away? The price in very good IMO and I would take the savings and purchase the optional skid shoes. Without draft control on the BX it (the shoes) make it very easy to set the needed height for leveling dirt or moving snow, etc.. I have them and also have the gauge wheels for the LP landscape rake that uses the same frame as the blade.
Hope this helps.
   / bx and lp1572 #3
Rear blade is an attachment---back blading is something you do with a blade. Just a little pet peeve.(just like people saying cement instead of concrete)
   / bx and lp1572 #4
Yes, hence the implement model RB (rear blade)1560, etc.. You're entitled to vent regarding pet peeves. We all could think of a few that drives us crazy.
   / bx and lp1572 #5
Thanks guys for the information. I do understand now about back blading vs the inplement "rear blade". Tractorbynet is wonderful!
2005 DIVERSIFIED FABRICATORS FERTILIZER SPREADER (A51247)
2005 DIVERSIFIED...
2011 Wacker Neuson RD12A, 36" Double Drum Roller (A52384)
2011 Wacker Neuson...
UNUSED CFG INDUSTRIAL MH12R EXCAVATOR (A51247)
UNUSED CFG...
2021 Bobcat S740 (A50123)
2021 Bobcat S740...
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
