BX Air Intake Disolved Platic/Rubber?
/ BX Air Intake Disolved Platic/Rubber? #1
bxonthelake
My BX1500 quit running and finally I found it wasn't getting air into the air filter housing. There was some sort of gooey rubber thing that had completely disintegrated and clogged off the inlet pipe. Can anyone tell me what this thing was for and has it happened to anyone else. I removed it and it is running normally now.
JD
Thank you, that sounds like it. I've never seen such a melted mess. It is some kind of rubber check valve. I can't even tell which way it was pointing on the pipe. Maybe mine is a defect in material, but it turned into a gooey mess. I've had this tractor since new and this is a factory part. If you touch it it sticks to you like chewing gum. Just a blob now. The way I understand it it is a coarse filter for the actual air filter. I don't operate in trashy environments, so if that's all it does, I'll leave it off. Unless someone can prove it harmful. Am I the only one with this melted part?
JD
/ BX Air Intake Disolved Platic/Rubber? #4
Nah, my turned to chewing gum too. Trivial to replace, $5 part.
/ BX Air Intake Disolved Platic/Rubber? #5
I've never understood the logic of that evacuator valve. If I had so much dust in my air filter casing that it would come out of that valve, I'd certainly open the housing and clean the inside and the air filter. It's made out of some kind of rubber that can't stand up to the engine heat, mine disintegrates fairly quick.
/ BX Air Intake Disolved Platic/Rubber? #6
Mine is still fairly intact. Maybe they changed the rubber formula? How many hours is on yours when it turned gooey?
/ BX Air Intake Disolved Platic/Rubber? #7
I've replaced two of them, one on the BX and one on the ZD. One of them turned to jelly and the other, some rodent chewed it up. I had a hard time finding reasonable replacements as the dealer wanted about $14 for one, found some online, but they were a little too big so put them on with wire a wire tie to tighten it . If someone will post the right size and where to get them, I will order some spares. Where do you find them for $6, I'd jump on some of those.
/ BX Air Intake Disolved Platic/Rubber? #8
The messicks link didn't work for me, but it sounds like the peice you are talking about might be the one that lets water out the bottom of the airbox.
/ BX Air Intake Disolved Platic/Rubber? #9
Without a doubt the evacuvator valve. Poor choice of materials by kubota. The valve is designed to blow out large particles as the air spins around the filter. Definently replace this piece. You will suck in all kinds of junk and trash your invaluable filter. Learned from burning through filters without it.
/ BX Air Intake Disolved Platic/Rubber? #11
Saw this thread pop up again so I started looking again. I found the Evacuator Valve at several locations, from $8.95 to over $10 each and then shipping over $10.00, I need three of them and didn't want to spend that much on $.39 parts. I found this link so I ordered 4 of them for $18.36 and $6.99 shipping. Here's a link.
Valve, Evacu | Part Number TA040-93250 | GUARANTEED FIT from Sears PartsDirect
/ BX Air Intake Disolved Platic/Rubber? #12
The one on the used BX2660 I bought had turned to chewing gum too. I bought a replacement from Messicks for $10.76 along with some other stuff.
/ BX Air Intake Disolved Platic/Rubber? #13
Slightly related to the subject. I found a listing on Sears PartsDirect for gage wheels for my Husquvarna ZTR mower for $3.99 each, for genuine Husqvarna parts. Just about a dime over half price from other suppliers. Ordered two sets at that price. Shipping was $6.99. I believe Sears is using loss leaders to bring in customers, lest they go belly up. Shipping was amazingly fast.
/ BX Air Intake Disolved Platic/Rubber? #14
Got my 4 evacuator valves and wrong size, they're too small, back to the drawing board. Part #TA040-93250 must be for the BX1500, sure doesn't fit the BX2200, ZD21 or RTV.
Edit: Best I can tell, the correct Kubota part # is K1211-82340 or Donaldson #P617632. The diameter of the part is 1.57"
2020 Hino Garbage Truck (A60352)
2020 Hino Garbage...
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A59231)
1990 21ft Center...
2001 Subaru Outback AWD SUV (A59231)
2001 Subaru...
Vermeer Vac trailer (A60352)
Vermeer Vac...
2019 Dodge Charger Sedan (A59231)
2019 Dodge Charger...
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
