Mowing BX 60in MMM Center Blade Not Engaging
   / BX 60in MMM Center Blade Not Engaging #1
gmikem206
NW NJ
Kubota BX 2660
Hi all, hoping someone will point me in the right direction. The center blade on the mmm is not engaging. I can easily move it by hand, and it does have a little bit of play or wobble. Would this most likely indicate a problem with the shaft assembly or a gear box problem? The outer blades are engaged and work fine. This is the RCK60B-23BX MMM on my BX2660. I'm going to pull the deck now and take a closer look.
Thanks, Mike
   / BX 60in MMM Center Blade Not Engaging #2
I would say the shaft blade center PN: K5371-33500, might as well replace the bearings too: PN: 08101-06205
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
(INOP) TOYOTA WAREHOUSE FORKLIFT (A51243)
(INOP) TOYOTA...
Wolverine Quick Attach Hydraulic Winch (A50514)
Wolverine Quick...
TRAILER AXLE (A51244)
2025 CFG Industrial TK35R Mini Track Loader Skid Steer (A50322)
2025 CFG...
UNUSED FUTURE GALVANIZED STEEL SITE FENCE (A51244)
UNUSED FUTURE...
