BX 54" deck will it fit?
/ BX 54" deck will it fit? #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
BX 54\" deck will it fit?
Does anyone know if a 54" deck will fit thru a 60" opening if you pull up the grass deflector. I'm hoping it will but I wanted ask the fellow BX owners.
/ BX 54" deck will it fit? #2
Re: BX 54\" deck will it fit?
Scrounger,
According to the Kubota Website, min transport width for the 54" deck is 56.5"
BX mower Decks
When I was shopping for my BX, the width of the deck was crucial because my door opening is only 58.5", so I actually measured deck widths at the dealer, and I can tell you that the width of the 54" deck, excluding the chute, is right on Kubota's specs at 56.5". So that would be the width with the deflector removed. As far as the width with the deflector pulled up, I'm guessing it still extends out a little from the deck itself, though I didn't measure it that way, because even with the deck off, I wasn't comfortable with just 1" clearance on each side.
If I could have gotten a BX1830 or 2230 with a 48" deck, I believe I would have, just for the extra horsepower, cruise control, etc. IMHO, Kubota should consider mating a 48" deck to these models. As it was, I was limited to the BX1500 because I couldn't accomodate the larger deck.
If you're facing the same situation, you may want to consider how much clearance you need. For a 60" opening, you've got a maximum of 3.5" total or 1.75" on each side. It may fit, but it may be a tight fit, and you may be gouging the door frames unless you going perfectly straight in or out. Also, if the tractor you're talking about has a FEL, the control stick module may also limit the degree to which you can raise the chute. One more thing, the chute on the 54" deck is steel, so it's not going to be forgiving on your doorframe like the composite chute on the 48" deck will. You might want to do like I did and measure one yourself on the dealer's lot, assuming there's one nearby.
Hope this helps. /forums/images/graemlins/smile.gif
Coveredbridge
Thanks so much, I never thought to look at the Kubta website. Duh. /forums/images/graemlins/smile.gif I'm set on the 54" since I wanted the larger deck. I'll make it work one way or another.
PS - Fill out that profile on yourself so we all know where your at and PA and etc.
Welcome to TBN BTW.
/ BX 54" deck will it fit? #4
We have a 5x10 ft utility trailer with an inside width of 59". We had to go with the 54" deck to fit on the trailer. There is about an inch clearance on either side with the deflector raised using a bungee strap.
Thats what I figured out. SInce my trailer is not been delivered yet I'm picking up on a 5x10 trailer so its going tobe tight. It heavy enough for the job, its just going to be tight. Time to load it backwards and I might remove the MMM and slide it in the Suburban for the trip home.
2012 John Deere 1770NT CCS Planter (A63109)
2012 John Deere...
2014 GENIE S-40 TELESCOPIC BOOM LIFT (A64279)
2014 GENIE S-40...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59910)
2018 FREIGHTLINER...
BUSHHOG 2615 LEGEND BATWING MOWER (A63276)
BUSHHOG 2615...
2016 Boxer 700HDX Compact Skid Steer (A63116)
2016 Boxer 700HDX...
John Deere 2750 Tractor (A64047)
John Deere 2750...
