BX 2750 Chute Problems?
   / BX 2750 Chute Problems? #1
Anonymous Poster
Epic Contributor
I have a BX1800 with a BX2750 snowblower that I purchased new last fall. First good snowfall of the season here today and first experience with this blower. The way the chute has been set up you have to rotate the chute back towards the operator to go from side to side. It will not point forward. Seems dangerous to me. I have disassembled and reassembled to no avail. Stupid install or stupid operator? Answers to either helps. Thanks
   / BX 2750 Chute Problems? #2
Something is wrong Huck, the chute should rotate away from the operator. Someone on this board must have a similar set -up that they can take a picture to show you how it should be. Is this a front or 3ph mounted unit? Is the chute rotator manual or power operated? Could it be that it was assembled backwards and the rotating mechanism is upside down and 180 degrees out. There has to be a simple fix.
I thought so too. I have a manual rotator on a front mount set up. I flipped the chute 180 degrees, but there are no teeth on that side of the chute for the rotator mechanism to mesh with. There is another picture on this site of a similar chute, but the chute on that one is oriented differently than mine. My chute is welded to the toothed base plate opposite the one I have seen on this site. The only way I can figure this one is to break the welds holding the chute on and reweld correctly - but that would be one for the Kubota folks.
   / BX 2750 Chute Problems? #4
I think you get n touch with your dealer tomorrow and have him deal with it. You shouldn't have to break welds, etc.
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A53473)
2003 International...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
2009 INTERNATIONAL PRO STAR+ (A53843)
2009 INTERNATIONAL...
2018 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2018 Allmand...
