Bx-2670 no dash lights, will turn over but not start
   / Bx-2670 no dash lights, will turn over but not start #1
theofile
Albany, NY
bx2670
Was mowing fine and then, puff. It stalled out and won't start again although turning over. Also, no dash lights. Jumped it to no avail. Turns over but won't start. Electrical fuel issue? What to do?
   / Bx-2670 no dash lights, will turn over but not start #2
It sounds like your fuel shutoff solenoid died.
Is there any clicks when you turn the tractor off? Usually my BX2200 does it about 20 seconds after switching it off.
   / Bx-2670 no dash lights, will turn over but not start #3
Check the fuses.. the 15 amp fuse labeled RELAY & the sol. fuse..
   / Bx-2670 no dash lights, will turn over but not start #4
I was thinking.. that sol. is energized to shut off.. not run..
SO if theres NO POWER to the solenoid, it wont shut off.. hmmm.
Yup. Found it - fuse. Replaced. Up and running. Thanks.
   / Bx-2670 no dash lights, will turn over but not start #6
I like easy fixes.
   / Bx-2670 no dash lights, will turn over but not start #7
Yep, easy fix, but why? Now you are aware, there may be a problem looming, rubbed through/chaffed wire, rodent damage, solenoid drawing too much current. So if it happens again, start having a good look around before just replacing the fuse.
   / Bx-2670 no dash lights, will turn over but not start #8
Good suggestions 100TD.. those solenoids get "gooped up & gummy" after awhile & draw a lot of current.. probably be a good idea to put some hands on it & check it..
Yes. Why? Previous in the week, my wife had taken the Bx out of the garage and left the ignition on. She doesn't understand. Hours later I tried to start the tractor, and the battery was dead. Jumped it and got it going. I'm thinking that the fuse may have been weakened by being used for so many hours. We'll see. I have instructed my wife - that's fixed.
NEW Work Saver Skid Steer/Sub Compact Grapple (A52748)
NEW Work Saver...
2005 CATERPILLAR 321C LCR EXCAVATOR (A51246)
2005 CATERPILLAR...
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2015 FREIGHTLINER...
(9) 2 PLUG VALVES (A52472)
(9) 2 PLUG VALVES...
