BX 25, When do Problems Start?
   / BX 25, When do Problems Start? #1
Tractor Seabee
Elite Member
Port Orchard WA Kitsap Peninsula, West of Seattle
Kubota BX25
I now have almost 5 years and 1300 HRs on my BX. Little things are starting to happen like glow plugs not working.
All you old kubota hands; what seems to be the trouble free life of the BX and what little things am I now facing? I am starting to wonder if there is a planned obsolescence on them to entice buying a new one. So far nothing is of a magnitude that I have not been able to fix myself. I am becoming well known at the parts counter.
Ron
   / BX 25, When do Problems Start? #2
A guy a worked for some last spring has a JD version with 2300 hours and trouble free. It had been gently treated.
Mine has not been "gently used". I bought it to work so it has worked but not abused. Most posts on here do not relate to the hours over time I have been working mine. Seems 50 Hrs a year is the standard.
Ron
Ron
   / BX 25, When do Problems Start? #4
SeaBee, you and I are in the same boat. You've replied to several of my posts concerning the BX22 I have that has 1300+ hours on it. I've done everything that I can from changing all fluids and filters, cleaning the strainer, to adjusting the valves, replacing propeller shaft cv joints, boots, hst fan, checked all glow plugs, shimmed the FEL relief valve. All this in the last couple months. I remounted the backhoe and now I'm chasing and replacing 13 year old leaking hydraulic lines on the backhoe. The first ones I had to replace were the pressure and return lines to and from the tractor to the BH. Tonight I'll be replacing both swing cylinder lines.
The previous owner of this machine used it hard from 2002 to 2013. The four hydraulic lines I've done have been relatively easy to replace. I dread day when I have to knock the pin out of the base of the BH boom to replace any of the lines that run inside the boom.
   / BX 25, When do Problems Start? #7
My fathers BX 23 has about 650 hours on it, he is not particularly gentile or even diligent about maintence. He bought it used with about 200 hours, maybe 5-6 years ago. Besides the stuff he broke due to his own doing, it has been bulletproof
   / BX 25, When do Problems Start? #8
I have had my BX 25 since 2009, and I have maybe 500 hours on it. The only thing that has gone wrong is it the 12 volt outlet has stopped working, probably simply because of the fuse. Will get to it as soon as I can.
I am very impressed by the fact that it starts even in very cold weather, as low as 30 below!
Oh, yeah, in the seat is starting to wear a little bit.
   / BX 25, When do Problems Start? #9
I only have 230 hours on my bx25 and have had no problems but a leak at the backhoe in a fitting. I have a ZT mower with a 21.5hp Kubota engine in it. It has over 3500 hours on it and I have done nothing to it but change the oil and filters. I think Kubota builds a long lasting product and if maintained, should last very long. I bought my bx because of the results I had with the Hustler mower and its engine.
Dakota 410 Turf Tender Topdresser S/A Trailer (A49346)
Dakota 410 Turf...
2022 CATERPILLAR 259D3 SKID STEER (A50458)
2022 CATERPILLAR...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
86" HYD QUICK ATTACH BOX BROOM (A50460)
86" HYD QUICK...
Lincoln Electric Vantage 300 Welder/Generator (A49461)
Lincoln Electric...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
