BX 25 rear PTO Cover problem
   / BX 25 rear PTO Cover problem #1
Larry Mac
I broke the rear PTO cover on my BX25. In replacing the cover I can't get the main drive shaft which turns the gear with the splines to go back in the case. It came out a little ways when removing the case. It need to move in about 1/2 inch. Do I need to disingage something to get this shaft to slide forward. It seems like a spline is not lining up but I have turned it with no success. The case installation looks simple but it has just about got me whipped.
Thanks Larry Mac
   / BX 25 rear PTO Cover problem #2
what is the pto selector on? try moving it to MMM only so the rear pto spins freely so you can turn by hand. hope this helps.
I have moved the selector and it will spin but the shaft still won't go all the way in. Thanks for your response. Any more idea's???
Larry Mac
   / BX 25 rear PTO Cover problem #4
unfornuately I do not. If I had a WSM (work shop manual) I'd be able to take a peek and look for ideas. In short- it looks like a teardown at this point if a call to the dealer for ideas doesnt work?
I guess nobody else has come across this problem. I am going to order a work shop manual and see what I find out.
Larry Mac
Finally success!!! I called several Kubota dealers in our area and they all said it should just slip right in. Well let me tell you that wasn't the case. After about 2 hours of trying to get it to slip in and getting zero success I knew I had to do something different. I took a piece of metal about 3/4 inch wide and 14 inches long and slid it umder the gear that is about 6 inches back into the case. After raising it up and down while I jiggled the shaft it finally slid together. I was one happy camper! I still have a shop and parts manual on order.
Larry Mac
   / BX 25 rear PTO Cover problem #7
Awesome!glad it fixed. I wish you posted pics of the whole ordeal though.
   / BX 25 rear PTO Cover problem #8
Larry Mac
Thank You ... I was panicking for a few momets
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A52577)
2016 PETERBILT 579...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
Komatsu Midi Excavator (A51691)
Komatsu Midi...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2011 Kubota R520S Articulated Wheel Loader (A51691)
2011 Kubota R520S...
