BX 25 Brake
   / BX 25 Brake #1
Bruce Macdonald
sticks and partially stayes depressed, need diagram showing lub points
   / BX 25 Brake #2
I checked the BX25 manual and my BX2370 manual and there does not appear to be a grease fitting for the Brake Pedal.
I would suggest you disconnect the brake linkage and then see if the sticking is in the pedal pivot or the linkage/brake itself. If it is the pedal "pivot" it should be easy to spray some lube in there while moving the pedal up and down.
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
(14) WOOD PALLETS (A60432)
(14) WOOD PALLETS...
2019 CHEVROLET SILVERADO 11FT FLATBED (A59905)
2019 CHEVROLET...
2022 Ford F-150 Pickup Truck (A59230)
2022 Ford F-150...
2024 CATERPILLAR 259D3 SKID STEER (A60429)
2024 CATERPILLAR...
