Looking through my BX 25 WSM there is no relief valve that sets the BH pressure less than the main relief on the tractor hydraulic circuit. There is an an overload relief valve that opens at pressures well above the 1850 you have in the power circuit. 1850 is the factory setting for the hydraulic circuit. The overload valve is to relieve any pressures developed in the BH system by operations developing an outside load. The BH, FEL, and 3 Point all operate at the 1850 PSI w/o any more pressure controls.
JJs pressure checking is right on except that the BH does not have a relief that controls the operating pressure.
Ron
Ron
Seems to me that most all BH would have their valve relief.
Can you explain how the over load relief works, and are you talking about work ports relief.
So if the loader relief is setting the relief for the BH then the BH could never exceed the tractor pressure of 1850 psi.
However the cyl could see pressure above that by mechanical force acting on the BH cyl. Each cyl work port would need a relief valve.
Can you show pictures of the relief you are talking about?
doghouse ,
Can you post the psi reading for each of the BH cyl using the retract mode until the relief goes off, if it ever does.
A good cyl will develop full relief pressure in fully retracted or extended mode.
Kubota BX25-LA240-BT601 | Backhoe Loaders Equipment Specs
Backhoe:
Backhoe type: Kubota BT601
Weight: 617 lbs [279 kg]
Digging depth: 73 inches [185 cm]
Reach from pivot: 103 inches [261 cm]
Loading height: 60 inches [152 cm]
Bucket force: 1,936 lbs [878 kg]
Dipperstick force: 1,171 lbs [531 kg]
