BX 24 will not go up a hill with a loaded bucket
   / BX 24 will not go up a hill with a loaded bucket #1
David Glaser
I have an interesting problem.
I have a 2006 BX 24 with about 500 hours of operation
The tractor will not go up an incline with a full bucket of dirt. However, I can back up the same incline with a full bucket (I have to put the tractor in 4wd mode to do this).
The hydraulic fluid is fine
Any ideas of what is wrong and what the repair costs might be?
-David
   / BX 24 will not go up a hill with a loaded bucket #2
What is the maintenance record on the hydraulic system. Fluid and filter change hours?
   / BX 24 will not go up a hill with a loaded bucket #3
Are you in low range? How are you using the forward-reverse pedal?
Brice
   / BX 24 will not go up a hill with a loaded bucket #4
Not enough information!
Wheel slip? Go pedal pressed to the floor? BAD!
Engine RPM ? Sounds? Performance on flat ground?
Make it into a story, Or else it's gonna cost you $47,987 to get it fixed. Cash in advance!
   / BX 24 will not go up a hill with a loaded bucket #5
.....................:D
   / BX 24 will not go up a hill with a loaded bucket #6
Have you tried in 4WD? Low gear? In 2WD your wheels are probably just spinning.
   / BX 24 will not go up a hill with a loaded bucket #7
more counterweight on the back is what you need.
   / BX 24 will not go up a hill with a loaded bucket #8
you have 4wd... use it
you have to be in low range
throttle way above idle
bucket off the ground
pedal pushed down 100%
Still not moving???
   / BX 24 will not go up a hill with a loaded bucket #9
-David
No where near enough information to draw any conclusions. You say it will not go up the hill. WHY won't it go up the hill? Are the wheels spinning inside the tires? (bead slip) Are you in 2 WD and the rear tires are slipping on the road surface? Are you in HI range and the relief valve of the hydro is opening?
Give us more information, write a book.
   / BX 24 will not go up a hill with a loaded bucket #10
-David
I am not mechanical at all but a friend had this exact same issue on his Kubota TLB. TBN won’t let him log on and he asked I relay his fix. There is a fuel bi-pass on the injector pump. A round knob. Turn that all the way in. His ran like new after he did that.
2013 Dodge Grand Caravan SE Van (A50324)
2013 Dodge Grand...
2016 John Deere 6155M (A50120)
2016 John Deere...
Landoll Hauloll (A52748)
Landoll Hauloll...
(9) 2 PLUG VALVES 1502 IRON (A52472)
(9) 2 PLUG VALVES...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2001 INTERNATIONAL 2574 6X4 (A51406)
2001 INTERNATIONAL...
