txkevin
So manual says loaded rear tires are OK but should be removed when the BH is installed. Who would actually do this each time the BH is added? Anyone have an opinion on this or experience with the loaded tires while the BH is installed.
The reason I ask is that I my landscape rake weight is about 200 lbs. According to my ops manual (if memory serves me correctly) I need about 350 lbs of implement for proper ballast to FEL. While I am not sure how many gallons (lbs) loading the rear tires will add, it seems it certainly can only help with the weight deficiency. I dont want to remove the FEL each time I use the landscape rake.
Am I on the right track here?
