BX-24 Loose Instrument Cover
   / BX-24 Loose Instrument Cover #1
DickS
U.P. MI
JD 265, Kubota BX24
Just noticed the plastic cover over the instrument panel on my '06 BX-24 is loose on the bottom. I suspect the dealer will claim "out of warranty", but thought I would seek board wisdom before I go there.
Has anyone else experienced this issue and what did you do to fix it? Did you remove the cover by prying it off and re-seal with silicon? All reasonable advice considered.
   / BX-24 Loose Instrument Cover #2
If it's like my bx23, the cover is stuck on with double sided tape. Mine came off and I stuck it back on with new tape.
   / BX-24 Loose Instrument Cover #3
I re-sealed mine with silicon...I also take the instrument cluster out when I wash it.
Deano
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
WESSEX CRX 240 LOT NUMBER 169 (A53084)
WESSEX CRX 240 LOT...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
2001 International 4700 Dump Truck with Compressor, VIN # 1HTSCAAN91H363922 (A51572)
2001 International...
2020 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2020 PETERBILT 567...
2023 BOBCAT T770 SKID STEER (A51246)
2023 BOBCAT T770...
