BX 24 Hydro failure
   / BX 24 Hydro failure #1
flatpik6
Bronze Member
Jacksonville, FL & Brasstown, NC
2011 Mahindra 5035, 2013 JD X738
Hello Folks,
A few weeks ago I posted a note about my low hours, (under 200), BX 24 having a Hydro failure. At the time I posted the note I didn't know exactly what had happened, but now I do.
I purchased the TLB from the original owner who also supplied me with all of the service reports from the dealer in FL where he purchased it new. One of the serrvice reports included a warranty repair that was cause from damage to the Hydro fan. The entire hydro unit had been rebuilt under warranty on 4/03/2009 as indicated on the invoice from that dealer. Incidentally, the tractor is a 2006.
So then recently while using the tractor in NC the Hydro gave way and made such a racket that it would have woke the dead. The unit stopped in the field and had to be towed back to my barn. I then had a local and well respected Kubota dealer, Nelson Tractor in Blairsville, GA come and pick it up. I must say that the Shop Foreman at Nelson Tractor, "Tom", was very diligent in communicating with me and staying informed as to the activities of the mechanic who was working on the tractor.
Skip to the important stuff....they discovered that when the Hydro had been rebuilt under warranty by the original dealer who has shops in FL and South GA, one of the thrust bearing assembies that operates against a rotating group of pistons had been installed backwards. Seems that the thrust bearing has two races, one much thicker than the other, that must be installed in the proper order. The thicker race must be installed on the pressure side against the rotating group of pistons. Mine had the thin race installed on the pressure side against the rotating group and subsequently broke in two from the pressure being applied. These two races are visibly different from one another and easily distinguished as "thick" and "thin". When the improperly installed race broke, then the whole shootin' match came apart. Metal everywhere. You outta see the bag of bones I recieved from Nelson.
This one improperly installed race cost me just shy of $2000 on a tractor that does not even have 200 hours on it and less than 30 under my ownership.
I am told that there is not much hope of getting any consideration from either the original selling dealer, (who did the first rebuild and improperly installed the race), or Kubota since I was not the original owner the unit is not in warranty any longer. That may be true but I think it is a grave injustice that I should have to foot the bill for this "documented" improper repair. The shop foreman from Nelson Tractor wrote a statement of his findings and copied the page from the repair manual that shows the proper installation of the race so I want to reach out to the proper people and see if I can get some consideration.
Can anyone here direct me on how to find out the name and contact info for the proper Kubota Rep in the S. Ga and N. FL area? I am going to write to the selling dealer but I would like to cc; the Kubota people so they are informed in the event I take my request on up the ladder.
Any tips on how to proceed with my requests and who to contact at Kubota would be greatly appreciated.
   / BX 24 Hydro failure #2
My gawd what an awful story. That would put me off my grits for a week. Sorry. :(
Warranty repairs are supposed to come with their own warranty. I can't remember how long and no idea if they transfer with ownership. Sorry x 2.
And this all started with that stupid plastic fan....
   / BX 24 Hydro failure #3
Sorry...I would be furious...
Yes, that stupid little plastic fan that costs an arm and leg to replace...they totally missed the ball on that.
You can try contacting Southeastern Kubota at 770-995-8855 (This number should have been on file with Nelson)...They are in GA and operate M-F 9-4...Not sure where that will lead ya, but it's a start.
Good luck...
   / BX 24 Hydro failure #4
I would simply contact the dealer that did the rebuild. He might just take care of the whole problem and not subject himself to embarrassment at Kubota. If you tell Kubota first, he may feel he has to defend his workmanship and might insist he did nothing wrong. Give him a chance to fix the problem.
   / BX 24 Hydro failure #5
oh man ! can beleive something like that happened to you. Glad you got it fixed though.
BXpanded,
That is exactly the path I plan to take. I too run a medium to large sized business and would much rather have a chance to work through an issue before it became a source of embarassment.
   / BX 24 Hydro failure #7
I would contact the dealer who did the first repair under warranty...Law vary from state to state and as post earlier said, warranty work has it's own warranty...and that would probably fall under the law from state to state. I am located in Alabama....Ga and Fl Laws are much tighter and stringient than Al laws on consumer matters such as yours. If the dealer and Kubota will not reach an agreemen with you I would advise you to contact an attorney that deals in consumer protection law. Probably find one in Atlanta.
I can relate to you in having had to deal with the incompetence of some one else.... I wish you much luck in working with the dealer you bought it from and the one who did the repair.
I wish that Kubota and other manufacturers would re-think this plastic fan....I realize to replace it would cost more $$$ and end result would be loss profits and loss sales to cheaper models but it would be more economical to at least put a steel fan instead of plastic if that is the only way. I had to replace the plastic fan on my CC 3186.....taillight assembly came loose and got tangled up in the fan and broke it into million pieces...I did the work myself and still cost me a day and $50.00.
Good Luck!!! T
   / BX 24 Hydro failure #8
I was doing some clearing in an area with a lot of small limbs and brush so I made a skid plate to protect my fan. while under the BX24 I noticed the fan was loose. One of the two bolts holding it on was missing. My tractor was a month out of warranty but the folks at Golden Eagle close to Pittsburgh replaced the fan without any cost to me. I highly recommend these folks. This is really a design flaw in my opinion. I still love my little tractor, a real pal.
2022 FORD F-250 CREW CAB TRUCK (A59823)
2022 FORD F-250...
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
2015 Kenworth T880 QMC 8060R 50 Ton Tri Axle Crane Truck (A60460)
2015 Kenworth T880...
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
1453 (A57192)
1453 (A57192)
John Deere 1025R (A53317)
John Deere 1025R...
