BX 24 Backhole Problem
   / BX 24 Backhole Problem #1
KellyNC
They delivered my new tractor late Friday afternoon. I didn't have time to check it out until today. The loader and mower worked OK. Tried to use the backhoe and could not get it to work. The boom did move slow from the right to the left, after that it would not move back. I had the throttle set at over 80 percent. Any one with a idea what is wrong?
I will call my dealer Monday and find out if they had check the loader out before sending it. The probable will have to come out and get it
   / BX 24 Backhole Problem #3
I'm sure you pulled out both safety pins.
The only other thing I can think of is to check all three hose connections for the backhoe.
Other than that, there may be air in your hydraulic lines which is compressing, rather than allowing fluid to flow. I'm not sure what the procedure is for bleeding the lines, but I think it is in the manual.
   / BX 24 Backhole Problem #4
   / BX 24 Backhole Problem #5
A quick connector isn't seated correctly. Check the ones for the backhoe first. They may look connected and not be, so you may have to disconnect and reconnect to make sure.
   / BX 24 Backhole Problem #6
Thank you for your help. I found a quick connector not seated
Super Star Smithco (A50324)
Super Star Smithco...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A52128)
Morooka MST 660VD...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A50322)
2017 Kawasaki Mule...
2009 GREAT DANE 53FT REEFER TRAILER (A52141)
2009 GREAT DANE...
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
