BX-23 UPGRADE ALTERNATOR
/ BX-23 UPGRADE ALTERNATOR #1
escavader
Veteran Member
western maine
bx-23 ,
Does any one know where i can get the 40 amp upgraded alt for the bx-23? Itried a few dealers online to no avail.One told me to go to my local alternator shop?:confused:AKubota part number would be very helpful.My current alt.isnt going to cut it,with all the stuff ive got in and out of my cab.
ALAN
/ BX-23 UPGRADE ALTERNATOR #2
I am interested in that info also. Hopefully it's a simple and relatively inexpensive upgrade.
Ken
Ken
KEN,
Iwas going to just hook up a car alternator or something,but there aint much room and i think it would be a pain in the ....to do.Mabey the bx-24 alt would fit???
ALAN
/ BX-23 UPGRADE ALTERNATOR #5
/ BX-23 UPGRADE ALTERNATOR #6
:cool:Your dealer can't get the 40 Amp upgrade Alt?!? Maybe they should called a proctologist to see of they can find their heads! :DTry Messicks. They know what their doing. Or here: The part for my BX was 15531-64017 and is available for $202 at Tractor Smart
/ BX-23 UPGRADE ALTERNATOR #7
The least expensive would be to get a rebuilt Hitachi 14231 Alternator from NAPA, Advance Auto, Auto Zone or O'rilies. See if it will mount and fit. It should. If it does not they should have no problem with you returning it.
That little alternator is used in a lot of applications. I believe it was originally used in the 80's Nissan pickups. Has been used in a lot of Japan motors since. And many conversions.
It is an internally regulated 40 amp very affordable, very reliable, should be LESS than $50.00.
You can wire it as a single wire alternator if you want. So hook up is very simple. KennyV.
STEVE,
Idid try the two you stated,oneof which told me to go local.Iwonder if the alt on your tractor is the same as mine?Im writing that number down just in case.Thanks
KENNY
ITHINK ILL STOP BY NAPA TODAY AND FIND OUT.Ill measure my shaft size and get a little better idea of what it looks like before i go.Thanks
ALAN
/ BX-23 UPGRADE ALTERNATOR #10
Thanks for the info. That will go into the manual for down the road a bit.
After I submitted the above line I looked up the alternator on the site and that number came up, Then I looked up dynamo and nothing came up. I'm wondering if that part isn't the original and not an upgrade?
/ BX-23 UPGRADE ALTERNATOR #11
The Dynamo will be a standard feature and , I would guess, not wildly sought after whereupon it would be only logical not to stock as every one would have one or better. I would guess you could get one if need be. Not a lot of complexities to a dynamo. My guess is they rarely fail.
IVE been researching calling different dealers and driving all day ,heres what ive got
this pic is of my current alternator.It is not referred to as that ,they call it a dynamo
Iended up at my dealer ,after going to parts stores,alternator shops,and calling dealers state wide.The lady at the counter showed me the two optoins,both that they had in stock.One was my current dynamo-,the other actually looked alot different ,actually looked like a car alternator.Isaid that cant be it,its not the same.Then the parts manager and service manager got togeather and went into the salesmans office and found an alternator kit that was not available in the parts computer,:confused:He said i think we have one:)He got CINDY[ the owner]and they went up in the attic overhead of the garage and found it.She had ordered it for a customer a few years back and he never took it.Now get this;it was the same alternator at the counter that lists alone for 315.Igot the whole kit bolts,bracketts wiring harness,the works for200 even[i dont know what the kit usually cost at todays pricing]:)Heres a pic of the kit and im gonna show pics of the install part number bx7310a fits all bx tractors im told.A BIG THUMBS UP TO OSGOODS for going the extra mile,and having lots of parts available
/ BX-23 UPGRADE ALTERNATOR #14
That is the very same alternator kit I had installed on my 1830
Much better than that OEM junk that came as standard equipment
You got an execellent deal
DGS
/ BX-23 UPGRADE ALTERNATOR #15
.She had ordered it for a customer a few years back and he never took it.Now get this;it was the same alternator at the counter that lists alone for 315.Igot the whole kit bolts,bracketts wiring harness,the works for $200 even[i dont know what the kit usually cost at todays pricing]:)Heres a pic of the kit and im gonna show pics of the install part number bx7310a fits all bx tractors im told.A BIG THUMBS UP TO OSGOODS for going the extra mile,and having lots of parts available
sounds like a good deal.
Congrats.
/ BX-23 UPGRADE ALTERNATOR #16
Escavader,
Thank you for the information. Looking forward to the pics.
I've had trouble at my local Kubota parts counter getting the correct number or part before. I don't think their system is very good. One time the parts guy happened to remember what the correct block heater was. Their computer didn't show it correctly. If I had ordered the part the computer said, it would have been wrong.
Ken
Im headed out to install now,lots of peices,poor instructions:eek:Ijust wanted to say ,that corrects the any bx statement ,the directions say the kit covers bx 1800,2200,1830,2230,22,and 23
ALAN
OK IM AS HAPPY AS A PIG IN MUD.It startes right up,and i turned every thing i got on on the tractor not even a wisker of tone change with the heater on high:):):)
FIRST THOUGHT The directions suck swamp water.so im gonna post my pics
Job 1 unhook negative battery cable
job 2 take off grill guard[if you have one],remove side panels
JOB 3 REMOVE OLD DYNAMO 2 bolts
Next you have to choose from the kit,which new tightening bracket you need.Itook the one from the bx22-23.Remove the old[2 bolts]install the new.GET the bushing and new bolt from the kit for the bottom.Ibelieve i used an old one for the top rough in the alternator.Before you tighten ,make sure its on all the pulleys.If its off on the bottom one ,its easier to crawl under and slip it back on,tighten it up according to your owners manual.
