BX 23 Hood Keeps popping up...
   / BX 23 Hood Keeps popping up... #1
vlpena
Bronze Member
Colorado County, Texas
Kubota BX23
Anybody with the "Bota BX23 having problems with the hood popping up? THe dealer said that would correct itself over time when the paint wera off near the latch????
   / BX 23 Hood Keeps popping up... #2
Sounds like the dealer doesn't want to make the adjustment....It is covered under warranty and he should take care of it before damage occurs to either your machine or your persona....
   / BX 23 Hood Keeps popping up... #3
My (BX22) does that when I am trying to close it. Mine also had the hood rattle from help after they put the new air filter bracket on. So I bent the hood, yes, holding both sides and pushed in SLOWLY. Bang, no rattle and the hood also stays shut weird.
   / BX 23 Hood Keeps popping up... #4
Doing a search I came across this post from BPD239 on 2-21-04.
<font color="blue"> "As for the hood....I figured out how to get the hood closed on the BX2200 without a major problem. I read that they had improved the BX23 hood, and I looked forward to seeing a big improvement. That isn't the case though, all that was changed was the way the locking pin is engaged/disengaged. The BX2200 had a straight push pull type lever on the dash which if you pushed in by hand instead of just closing the hood and hoping the spring pulled it forward, worked fine. The BX23 hood is identical, the pin and hood catch are the same, but now you can't just push the pin forward. I found you have to wiggle the hood to get it to close" </font>
...also do not hum "Pop goes the weasel" as you're driving around... /forums/images/graemlins/grin.gif
Txdon,
I know who you are and I saw what you did!
You better get to studying!
Thanks for the info on the latch, I will catch up with you later, dude! /forums/images/graemlins/cool.gif
   / BX 23 Hood Keeps popping up... #6
</font><font color="blue" class="small">( THe dealer said that would correct itself over time when the paint wera off near the latch????
)</font>
I think your dealer is full of poo,poo(hows that, moderators?) i think something just need to be ajusted.
Thanks Frank...I was wondering why the salesman's eyes were so brown!
I think TXDON "hit it" right on the head... wait a minute...
that' s what I'll do, just give it a good Texas slam...yeah that's the ticket!
   / BX 23 Hood Keeps popping up... #8
VlPena,
when I went over my 23 with the mechanic at purchase, he had a little difficulty closing the hood. He said the same thing as your dealer. The latch is stiff when new. I have 49 hrs on mine and I check the oil before each start. The first time or two I had to hold the hood down while pushing the hood release lever to the lock position. As my dealer had said it would, It broke in fine and now has a positive latch everytime I close it.
Steve
John Deere 2700 Mulch Ripper (A50514)
John Deere 2700...
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
1986 John Deere 772B Articulated Motor Grader (A49461)
1986 John Deere...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
1999 John Deere 566 Round Baler  Net & Twine, Reliable Performance (A51039)
1999 John Deere...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
