bx 2230 steering
/ bx 2230 steering #1
gravedigger
Has anyone had problems with their steering on a 2230.If you turn the wheel nothing happens until goes almost all the way around thanks in advance
/ bx 2230 steering #2
I have not had that problem. Sounds like either low fluid or air in the system for some reason.
If not that there is some larger problem.
/ bx 2230 steering #3
gravedigger
I've had my BX2200 for two and one half years. No steering problems to date.
John
/ bx 2230 steering #4
</font><font color="blue" class="small">( I have not had that problem. Sounds like either low fluid or air in the system for some reason.
If not that there is some larger problem. )</font>
I have never had any problems like that on mine. You must have an air trap.
/ bx 2230 steering #5
I had this problem on my BX2200. If you turned the wheel slow, you could turn forever and nothing would happen. If you turned it quickly, it caught and the steering was fine. The tractor would also wander when going straight.
The dealer replaced several components. Turned out it was the hydraulic cylinder up front. Apparently some had gotten contaminated with moisture and the fluid would leak by.
/ bx 2230 steering #6
</font><font color="blue" class="small">( I had this problem on my BX2200. If you turned the wheel slow, you could turn forever and nothing would happen. If you turned it quickly, it caught and the steering was fine. The tractor would also wander when going straight.
The dealer replaced several components. Turned out it was the hydraulic cylinder up front. Apparently some had gotten contaminated with moisture and the fluid would leak by. )</font>
I had the same problem. Dealer replaced steering components under warranty. /forums/images/graemlins/cool.gif
Terry
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
2015 FREIGHTLINER M2 4X2 S/A 26FT REFRIGERATED BOX TRUCK (A59914)
2015 FREIGHTLINER...
HPX John Deere Gator (A65579)
HPX John Deere...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
2017 Metso Lokotrack ST2.4 Screen Plant on Tracks with Feeder (A65579)
2017 Metso...
Metal Sasquatch (A65583)
Metal Sasquatch...
