BX 2230 Fuel pump noise
   / BX 2230 Fuel pump noise #1
roaf3x
Bronze Member
My Dad was bush hogging and when he stopped he could hear the fuel pump with the key on and the engine off.
He also said it was hot to touch.
He has 400 hours on the tractor .
Any thoughts on the noise or the heat??
Roaf3x
   / BX 2230 Fuel pump noise #2
On my BX, the pump is running while preheating, engine off, key on. I'd say its normal for 2230 too. I'd imagine it would be hot due to heavy use so I wouldnt worry too much about it. I'd just have to check mine.
The issue is the noise is 10 x louder than it ever was .
Do these pumps go bad internally?
   / BX 2230 Fuel pump noise #4
My BX is the same, pump runs when preheating, audible clicking, have never checked for heat, will have to do so.I have 1500 hours on my BX.
UNUSED AGT 46" EXCAVATOR HYD BRUSH FLAIL MOWER (A51248)
UNUSED AGT 46"...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53472)
2016 RAM 5500...
UNUSED ALLMETAL K0311-10' GALVALUME STEEL (A51248)
UNUSED ALLMETAL...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
6ft Pull Type Hydraulic Dirt Pan (A51573)
6ft Pull Type...
2018 John Deere 6215R MFWD Tractor (A53342)
2018 John Deere...
