BX 2200 one injector not getting fuel any ideas?
   / BX 2200 one injector not getting fuel any ideas? #1
robinj1000
Tractor started running rough #3 injector not getting any fuel any ideas out there. I live way out in the woods no dealers near by Thanks in advance
   / BX 2200 one injector not getting fuel any ideas? #2
How did you determine #3, if you loosened the line from the pump out to the injector if fuel maybe injector, interchange the injector with another cyl and see if problem switches or remains the same. I have taken injectors to repair shop they are able to test and rebuild if necessary, also very little charge compared to new injector, Before you start this be sure the area is clean and keep the lines covered so dirt can't get in the injector. and don't use finger to test pressure it will inject diesel into skin,
if think injectors are good maybe a valve staying open how many hours, and past problems?
se'ya ken
   / BX 2200 one injector not getting fuel any ideas? #3
If you think you have a cylinder that is not getting any fuel, fire up ol bessy and let her get up to operating temp. THen use an infrared thermometer and measure the temp at the exhaust manifold for the 3 cylinders. If they are essentially the same, within a few 10's, then there is anotehr problem.
   / BX 2200 one injector not getting fuel any ideas? #4
robinj,i am a diesel mechanic,the first thing you need to do is loosen the nut on the injector line at the pump if there is no fuel spraying out you have a bad pump,if there is fuel there tighten that nut back then loosen it at the injector,if there is no fuel there the line is stopped up or damaged.hope this helps!
2012 KAWASAKI 70 ZV2 WHEEL LOADER (A53843)
2012 KAWASAKI 70...
2021 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A54313)
2021 FREIGHTLINER...
TAKEUCHI TB250-2 EXCAVATOR (A52705)
TAKEUCHI TB250-2...
TORO TR20 WALK BEHIND TRENCHER (A51406)
TORO TR20 WALK...
2012 INTERNATIONAL LF687 (A53843)
2012 INTERNATIONAL...
2018 DRAGON 130BBL VACUUM TRAILER (A53843)
2018 DRAGON 130BBL...
