Mowing BX 2200 (2002 Model)
   / BX 2200 (2002 Model) #1
tb4192
I have a BX 2200 with a 54" MMM. The right rear link keeps coming out dropping the mower deck. Once the right comes out the left eventually does as well. Is there an adjustment that can be made or is it more likely something broke allowing this to happen. I cannot tell if any thing is missing as I honestly don't view this part of the tractor / MMM that often.
Thanks!
   / BX 2200 (2002 Model) #2
There is a spring on mine that looks like its design is to keep the pin from slipping out. Does yours have a spring? The spring is on the L shaped pin that you pull out to take the deck off the tractor and it connect the deck to the lift arm.
I described it incorrectly. The L shaped pin is what's slipping out of the deck. Not sure how because there is a spring that allows the L pin to be pulled back. When it comes out I lift the deck up and pull the pin back and guide it back into the hole on the deck.
   / BX 2200 (2002 Model) #4
Sounds like a worn out spring. Tension seems ok?
Could be. I will check tonight. Thanks!
   / BX 2200 (2002 Model) #7
Hahaha...yeah...broken bracket...ask me about this issue...LOL.
Thanks to anthonyv for beating me to the punch!
UNUSED FUTURE 32" HYD TILTING BUCKET (A51248)
UNUSED FUTURE 32"...
2025 K1230 UNUSED (10) Wire Mesh Netting Rolls (A53117)
2025 K1230 UNUSED...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
Michigan L-90 Wheel Loader (A52384)
Michigan L-90...
2018 Mitsubishi Mirage ES 4D Hatchback (A53117)
2018 Mitsubishi...
