BX 22 with Tiny Tach
   / BX 22 with Tiny Tach #1
Jimbrown
Veteran Member
Tombstone Az
KIOTI LK30
What RPM do those of you with Tiny Tach get at idle and full throttle. Mine seems to idicate fast but I have no way to test it or calibrate it. I get 1280 at idle and 3360 at full throttle.
   / BX 22 with Tiny Tach #2
I wish I could help you there. Mine doesn't even have one. Probably not necessary, but I'd like to have one anyway. (B6100 HST-E)
   / BX 22 with Tiny Tach #3
I'd like to help you, Jim, but I whacked my TinyTach with a fence rail that fell off the FEL a couple months ago and have to replace it...the display is trashed. But if my memory serves me, your readings are't far off from what I get on my BX22.
   / BX 22 with Tiny Tach #4
I'll run mine tomorrow and let you know idle. I'm not to 50HRs yet, so don't know full throttle yet.
Ron
   / BX 22 with Tiny Tach #5
I have a BX2200 and no tach. I also have a B2910 with a tach.
When I mow with the BX, I just put the throddle full on (now have over 50 hours) and mow.
When I do other things with the BX, I just set the engine speed by ear.
So I have to ask, what does the tach on the BX do for the operator? I am not sure if I even need the tach on my B2910 actually. I do use it to set RPM at "550" for my rotary cutter, but other than that I never run at full PTO rpm anyway....
AT this point in time I don't know if I want to bother with a tach on my BX at all. And I am pretty sure I don't, actually...
   / BX 22 with Tiny Tach #6
But Henro, it looks cool--like a bigger tractor!
I can't believe you don't want one.
Ron
   / BX 22 with Tiny Tach #7
Don't forget to remind Henro that it gives him another chance to drill holes in his tractor!!!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / BX 22 with Tiny Tach #8
On my 2200 that sounds about right. The idle seems fast but mine has always been that way. I normally mow between 1900 and 2300. Blowing snow I run at full speed and you know, I have never looked at the tach when I an blowing snow....guess I just figured that full speed was full speed...next winter I'll remember to look and see what the rpms are!
   / BX 22 with Tiny Tach #10
I understood that you ALWAYS run implements at full throttle on the BX, since that is the correct RPM for the PTO. I cut at full throttle, find that less usually does not cut as good. Tilling, full throttle does so much better with my clay soil anyway. I have a KK 48" about as big as you can get for this size tractor.
2010 MULTIQUIP 25KW GENERATOR (A53843)
2010 MULTIQUIP...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
MISC BASKET OF HYDRAULIC PARTS (A53843)
MISC BASKET OF...
2020 Mclanahan 150 TPH USP Wash Plant (A52377)
2020 Mclanahan 150...
WHITCO PRESSURE WASHER AND STEAM CLEANER (A53843)
WHITCO PRESSURE...
SKID STEER HYDRAULIC TREE PULLER (A53843)
SKID STEER...
