crawdad
i drove my bx22 about a mile to my buddys house to help him dig out some stumps,grade the
driveway a little and do some heavy rock digging.
the bx22 was workin real hard for about 4 hours.
we are just finished i move the machine away from where we are working ,
i dropped the throttle from about 2800 rpm down to idle real quick, (by accident)
the engine dies.
will fire up w/key and stall.
check connections etc. .....cant figure it out.....
get a ride home get my truck w/trailer and tools.
i was somewhat low on fuel.thought maybe a little lock-up.add more fuel. i cracked the fuel lines open.
i had fuel.
my friend says how 'bout the fuses.......he was right
the 20A solenoid fuse is blown. check for damaged wires....nothing....install new fuse.
turn the key....fuse pops......h'mmmmmmmm............check connections again....look at wires....
install another fuse.....it pops.........h'mmmmmmmmm
i go to winch it up on the trailer (thank god the front loader was up halfway) forgot the remote switch....
short piece of wire jump that out......get it on trailer.....get it home.......check some other stuff w/voltmeter
check the ignition switch harness....seems ok....put in another 20a fuse.....she fires right up.....
anyone care to give some thoughts as to why the fuse kept blowing?
seems as she cooled down she started right up....
seems to be working fine....
was always in neutral to start
cant figure this one out
thanks
scott
the engine dies.
i had fuel.
thanks
scott
