BX 1860 Stability?
   / BX 1860 Stability? #1
DIXIEDOG
Platinum Member
Maine
International 2544 / Gator 825i/L2501/General
Well I've been using the little BX 1860 to do some minor snow cleanup in areas that aren't convenient to plow with my Gator/Boss combo and I've got to say the little tractor feels downright tippy to me. I do have a weight box on the hitch with 300 lbs of ballast in it and also the Kubota wheel weights. I believe the wheel weights were around 40 lbs each but I can't remember for sure....the tires on a 1860 are pretty small so it could even be a little less.
I was going to have the tires filled with beet juice but the dealer claims that it won't make any difference because the OEM tires on a Kubota BX are so small they don't hold much anyways. Does anyone have first hand experience with a BX1860 and liquid filled tires?
I know on my International 2544 it makes a huge difference but the tires hold around 800 lbs of liquid too.:laughing:
   / BX 1860 Stability? #2
No experience with filled tires but i can tell a differnece with 2" spacers on my BX25D which is a Bx2370 basically. Wheel spacers and filled "little tires" may help.
Tire spacers seem like a good idea, I hadn't thought of that one. Wider track would help stability for sure
   / BX 1860 Stability? #4
My BX1860 rear tires are filled. They have been filled since new so I can't speak to improved stability. I'm not sure if you are talking side to side stability or a light rear end when using a loader. I have never noticed a side to side problem but need weight on the rear hitch when using the loader even with the filled tires.
   / BX 1860 Stability? #5
My BX23 can get a little puckerey sometimes....Never rolled it, but came close..Often I'll leave the BH stabilizers out just to be safe.
The machines are somewhat narrow so the rear spacers would probably help, don't know myself though.
It's side to side that feels unstable....if you're driving over a small hump like 6" high with one tire at any angle it feels like it's going to tip. The loader doesn't cause a problem, it doesn't really lift enough weight to be a concern, the box ballast is plenty for that.
   / BX 1860 Stability? #7
"Little BX 1860"
"little tractor"
"tires on an 1860 are small"
"OEM tires on an 1860 are so small they don't hold much"
All in the same post! Sounds like a case of "small tractor-itis"! You'll never be happy until you trade it for a bigger one! :)
   / BX 1860 Stability? #8
Do you have any pictures of your weight box? I am wondering if that could be the problem. Consider how high it is being carried, it could be negating your wheel weights. If you are just doing snow maybe you could try it without the weight box. I have a box I made to carry firewood on my BX24. When I have it full I can feel the shift in stability and any added lift makes if worse.
Doug in SW IA
   / BX 1860 Stability? #9
You have to consider a 6" bump is to a BX what a 15-18" bump would be to your big tractor. Also, I've found the bare BX tractor is very good on slopes, but things change a lot when the FEL is mounted. The FEL needs to be kept low for travelling and you do want all the weight you can get over the rear axle... weight box, implement, filled tires, your own weight, etc. The beet juice does make a difference, and whatever is on your 3pt needs to be kept low. Also, make sure you have enough tire pressure.
   / BX 1860 Stability? #10
I don't have a BX 1860, I have a BX 2230, but I believe the tires would be the same. Mine are filled with washer fluid. Beet juice is much heavier. I figure I added 90 lbs to each tire by doing so. You added 40 lbs in weight, but 90 more wouldn't help? Nonsense. It made a huge difference on mine and I don't have spacers.
2022 Club Car...
2001 Dodge Ram Ext. Cab Pickup Truck (A48081)
2001 Dodge Ram...
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A48836)
2007 Isuzu FTR...
More info coming soon! (A48082)
More info coming...
2012 Bomag BC572 Refuse Compactor (A49346)
2012 Bomag BC572...
2015 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A49346)
2015 Caterpillar...
