BX-1860 compatible with LA211 Loader?
   / BX-1860 compatible with LA211 Loader? #1
r0GuE
Veteran Member
West PA
ex-Bota Owner
I have a guy interested in my loader that I am selling. I have a BX-2200. He has a BX-1860. Will it blend... er uh, I mean fit properly? :)
   / BX-1860 compatible with LA211 Loader? #2
Do not think so have LA211 on my BX2230, Should only fit the BXxx00 and BXxx30 series.
I think the BXxx50 and BXxx60 series have built in valves and loader mounts that are different.
David Kb7uns
   / BX-1860 compatible with LA211 Loader? #3
What David said, the connections are different. On the 2200, you loop one of the hoses back into the tractor when you dismount the loader, the 60 Series has all four connections still on the tractor.
I don't know however if it could be re plumbed to work as that is well beyond my abilities.
Thanks guys! Thats all I needed to know. TBN Does it Again!
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
INOP/NON-RUNNING 1990 Ford F-150 Pickup Truck, VIN # 1FTDF15Y1LNA65905 (A57453)
INOP/NON-RUNNING...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
