buying trailer - any experience with doolittle or lawrimore?
   / buying trailer - any experience with doolittle or lawrimore? #1
wango tango
Peoria IL
the trailer i (think i) want is a 14k tandem axle single wheel 18+2 bumper pull (2 5/16").
the local dealer has a doolittle for $4400 firm
a dealer about an hour away has a lawrimore for $3450 (quite a difference)
the doolittle has ez-lift ramps, they really are easy to lift! also has braces built in. you can also remove them. it has removable fenders as well. it seems to be a very well built trailer.
the lawrimore i dont know as much about, i believe it has detachable ramps. not sure about the fenders.
the $1000 price difference is hard to ignore. wondering if any of you have experience with these trailers.
also, if anyone wants a liberty patriot 16' 7k trailer, let me know :)
   / buying trailer - any experience with doolittle or lawrimore? #2
I HAVE AN 1996 DOOLITTLE TRAILER ITS IS AN 7K 16 FOOT ITS BEEN A VERY GOOD TRAILER I OWNED IT SINCE 2000 I GOT A NEW TRAILER A FEW MONTHS AGO TO MATCH NEW 1 TON I WAS PULLING THE 7K WITH A LD 3/4 TON FOR 4200 I GOT A 10K MAXUM MADE BY CAM FOR A 20' 14K THEY WANTED 5500 IS THAT A DECKOVER YOU ARE LOOKING AT GETTING
no, it is not a deckover. the fact it has removable fenders makes me think it would be ok if i had something wide, i could just drive over the tires on the trailer.
anyone else have any thoughts?
i am pretty sure i want removable ramps, and at least 20' and maybe 22 (or 24?).
   / buying trailer - any experience with doolittle or lawrimore? #5
I saw a Doolittle trailer today. Looks well made, but, skimped out in some areas (at least the 2 I saw on the lot). Wiring could have been better (cheap connectors), break away battery was in an awkward spot with no test button, I wasn't so much a fan of the ramp ends (looks like they could bend easily). Other than that, looks like a beast!!!
FWIW, I bought a 20' Maxum 10k for $3850, they offered me the 20' 14k Doolittle for $4250.
   / buying trailer - any experience with doolittle or lawrimore? #6
Lawrimore great trailer - solid. Almost bought one of their dumps. Good value for the money-compare the specs and the construction and the welding.
   / buying trailer - any experience with doolittle or lawrimore? #7
I own a Lawrimore 83x20 with 5300lb axles and adjustable pintle hitch, its been a great trailer! They are built very well!
   / buying trailer - any experience with doolittle or lawrimore? #8
Where are you from? The reason I ask is Lone Wolf trailers factory is just down the road from Lawrimore. They have really good looking trailers as well. It was hard deciding between the two.
2016 Dodge Charger Sedan (A42744)
2016 Dodge Charger...
1991 TOYOTA LAND CRUISER FJ80 (A45046)
1991 TOYOTA LAND...
JBI Spray Booth Air Filtration System (A42742)
JBI Spray Booth...
Kivel Pallet Forks (A44502)
Kivel Pallet Forks...
Allied Hammer Attachment (A42021)
Allied Hammer...
PT 1000 Gal Supply Tank (A44501)
PT 1000 Gal Supply...
