Buying tractor which tires?
   / Buying tractor which tires? #1
sms0000
Ontario, Canada
Kubota B3200
Buying B3200 it has R4 Industrial tires on it now, I have never owned a tractor before ...... how much to switch to turf or ags? OR are they all the same price and which is best for me?
I have 15 acres wooded land with good road and trails on it, I also plan on being across many lawns with it using BH and lanscaping and such (not mowing with it) and will use to plow/blow snow with in the winter. Any advice on which tire is suited best? I am not opposed to buying chains if necessary for the best of both worlds.
   / Buying tractor which tires? #2
For what you describe, the R4 seems to be your best choice. See what it is like in the snow. You can add chains later if needed.
Switching is usually expensive unless you really need a specific tire for a specific use. Nearly all of the time, the turf and ag tires use a different rim and sized tire. Requires not only new tires but also new rims.
   / Buying tractor which tires? #3
I've had quite a few tractors and along the way have tried Ags, turfs, and R4s. I live in the rocky mountains, so all of my tractors have had chains to use in the wintertime.
I just had to decide what tires to order on a new M59....and chose R4s. Turf tires ran a close second, and ag tires a far distant third. In a nutshell, the tires depend on your soil type. Any of those tire types will benefit from chains in snow. I now use chains only on the front wheels in the 4wd tractors.
Ag tires will chew up lawns in short order. Ag tires are originally designed to provide heavy machinery traction in soft dirt. Think of plowing. On light machines they just spin the tires and so aren't as useful on compacts as they are on farm tractors. It surprised me how much traction that turf tires have, but they are softer rubber and don't hold up as well as R4s for loader work. They do give a more comfortable ride. Another advantage to the turf tires is that they usually lower the CG a few inches and the wider ones definitely help side hill stability. But the R4s do all those good things nearly as well as the turfs, are way less expensive, are much more durable than either, and have sufficient traction to do reasonable work in snow and mud without chains.
rScotty
   / Buying tractor which tires? #4
rScotty
Read no further! You just got the best advice you'll get. Be prepared though, because I see some big smiley faces headed this way just coming over the horizon:)
   / Buying tractor which tires? #5
Maybe since he has a bunch of "little" BX's he will see this isn't like his.
I have a BX2660 with turf by choice and a B3200 with R4's by choice. Have never tried or considered ags. The R4's and turfs have been the same price on all the tractors I have bought. The R4's are great all around tires.
   / Buying tractor which tires? #6
There are pros and cons to each.
R4's
Pro's
Tougher more puncture proof
More traction
Tougher side walls for heavy FEL work
Designed for pavement
Con's
Rides harder
Will tear up wet lawns
Not so good on ice and doesn't like chains as much as turfs
Turfs
Pros
Softer ride
Like a pair of sneakers over your lawn even wet
Handles chains better for ice
Designed for lawns
Cons
Wears out faster
Easier to puncture
Less traction
Snow is kind of a wash. Depend on depth, type and weight of tractor. Sometime turf will be better because it's a softer tire sometime r4 will be better because it's deeper tread.
   / Buying tractor which tires? #7
R-4's are an all purpose tire that might leave you stuck in real muddy spots, but otherwise perform pretty well. Even when I cut with R-4's, they won't do any lawn damage as long as it isn't soft/muddy.
Turfs are best when minimum lawn damage is important.
Ag's are best for the most demanding traction situations or pulling ground engaging implements.
Rule of thumb: As the traction goes up-so does the lawn damage. That's probably the easiest way to look at it.
   / Buying tractor which tires? #8
rScotty
I agree with HARPOONALT. Very good advice and post.
   / Buying tractor which tires? #9
Snow is kind of a wash. Depend on depth, type and weight of tractor. Sometime turf will be better because it's a softer tire sometime R4 will be better because it's deeper tread.
Good post as written, but wanted to add to the snow part. I have both types of tires for my tractor.
I Push the snow and have found that the Turfs work much better providing the best reaction with the least tire slippage. When pushing snow you generally are not driving through the deaper snow and resistance to slippage is desired. The turfs have more edges and will provide better traction under slippery conditions. I have also had good luck going through the deeper snow with the turf's on.
I also feel that the larger voids on a more aggressive tire, like the R4, may be more advantageous if I were to be pulling snow with a back blade.
The above comments are based on my tractor being four wheel drive. and I seem to have too much fun driving my tractor during the first few snow falls of the season. especially compared to the older two wheel drive model I replaced.
Thanks for the info guys......my thoughts also lead me to believe that turfs would provide better traction in the snow/ice per the extra edges on the tires. I think R4's will be the best all around for me though ..... puncture resistance means alot to me and not really concerned with wet grass damage.
Thanks Again
UNUSED Tool Set (A53117)
UNUSED Tool Set...
UNUSED LANDHONOR LHR-BLC9021 TOOL STOOL (A54757)
UNUSED LANDHONOR...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
Kubota BX2230D (A47384)
Kubota BX2230D...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
