Buying steel for coupons
   / Buying steel for coupons #1
deereman75
Veteran Member
canada
Deere 2120, Warner & Swasey 6000# offroad forklift, Case W9B loader, various non-running decorations
I have finally ran out of scrap steel for practice pieces. With the amount of fillet welds I am needing to do for practice, and testing, I have decided to just buy it.
I am looking for a bit of advice before I shell out the cash.
I am thinking of going with 1/8x1 hot rolled flat bar. It will cost me $0.86 per foot.
Any other suggestions? I mainly run 1/8 rods.
   / Buying steel for coupons #2
   / Buying steel for coupons #3
Get at least 1/4" flat bar. I think 1/4" x 2" and some 1/4" x 1" to weld onto it would work for fillet welds. Make a few pieces so you can let them cool off between welds. You don't see too many tests for fillet welds. Most tests are on butt welds.
Okay, the experts have spoken.
I will call metal supermarket on Monday for a quote on 3/8x6 inch bar, and some 1/4x2 bar.
I am also thinking of picking up some angle to make a burning bar. That should make torching them to size a lot easier....
I'm not sure if I should use the torch, or the 9 inch grinder to bevel the plate.
I'm thinking of 5 feet of the 3/8x6 bar, and 10 feet of the 1/4x2
Anything else I should get?
I might have to build a cutting table.....
Oh, shieldarc, what was that welding book you recommend as the first one? I want to order it.
   / Buying steel for coupons #6
On the thinner material you'd be surprised how fast a 9-inch grinder will bevel coupons!
If you use angle iron for a burning bar, sand it as smooth as you can with a fine grit disc. Then rub soap stone on it, so the torch will slide easier.
   / Buying steel for coupons #7
I will dig through the old threads, and try to find it.
I have seen you post parts of it a lot.
Metals and how to weld them was the one I was thinking of.
I think I will order both of them.
   / Buying steel for coupons #10
This is a good book too. It has a small section on heat shrinking material. Good skill to have when working with metal.;)
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A53117)
2025 K0311 UNUSED...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2025 CFG Industrial H15R (A50123)
2025 CFG...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
